how do i install VWIC3-2MFT-T1/E1 on 1921 router ?
dolanduck.
My friend gave me 4 VWIC3-2MFT-T1/E1 that he got for free from his networking friend. anyway i wanted to use this cards for my home lab to practice for CCNA. i installed them but it says that i need commands or something.
cmarva
Level 4
Level 4
you will need to configure using the card type command. Either check the command reference on cisco's site, or:
conf t
card type ?
I don't think the card is supported on the 1921 at all. Check Table 2 of the attached document. After installing the card and rebooting the router, does the card show up in 'sh ver' ?
https://www.cisco.com/c/en/us/td/docs/routers/access/interfaces/software/feature/guide/vd-t1e1_4p_vwic3.html
not sure if it will show up in a sho ver until the card type commands are in place.
but if it is recognized by the router it would show up when you issue "sho inventory"
