How do I use IP SLA source-interface as Loopback 0
Lei.LIM
Frequent Visitor
Frequent Visitor
HI all.
I want to use IP SLA source-interface as Loopback 0
R1's config
ip sla 1
icmp-echo 2.2.2.2 source-interface loopback 0
ip sla schedule 1 life forever start now
track 1 ip sla 1 reachability
ip route 2.2.2.2 255.255.255.255 192.168.1.2 track 1
I set it up like this
2.2.2.2 is not visible in the routing table
The link is not connected at the time of sh ip sla sum.
Is there anything wrong with me?
11 Replies 11
in R2
ip route 1.1.1.1 255.255.255.255 192.168.2.x <<- this for return back traffic
Note:-
in router w/o NAT and w/0 default route
do command show ip route
you must see ALL ALL route in your network
Of course, return routing exists in R2.
But I didn't apply SLA to R2 and I'm testing it.
Only static routing is applied.
Ping R1 at R2 is normal, but there is no routing of R2 due to SLA operation in R1.
Can't source-interface be applied as Loopback 0?
Thank you in advance.
share config of both, and Yes you can use LO as source.
R1
ip sla 1
R2
ip route 1.1.1.1 255.255.255.255 192.168.1.1
thats all
is there something wrong?
Yes but where is
interface Loopback 0
ip add 1.1.1.1 255.255.255.255 OR ip add 2.2.2.2 255.255.255.255 ??
Yes both routers IP
R1 1.1.1.1 255.255.255.255
R2 2.2.2.2 255.255.255.255
share all config
share show ip interface brief
you need to enter the Loopback interface with
in R1
in R2
R1#sh run
Building configuration...
Current configuration : 3305 bytes
! Last configuration change at 09:33:23 UTC Tue Aug 2 2022
version 15.6
hostname R1
boot-start-marker
boot-end-marker
enable secret 5 $1$bCYO$QNN8UW6sM7BpZrszboGNT0
enable password a
no aaa new-model
ethernet lmi ce
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip cef
no ipv6 cef
redundancy
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface GigabitEthernet0/0
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
ip address 192.168.3.1 255.255.255.0
duplex auto
speed auto
media-type rj45
bfd interval 500 min_rx 500 multiplier 5
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/3
no ip address
duplex auto
speed auto
media-type rj45
no mop enabled
ip forward-protocol nd
no ip http server
no ip http secure-server
ip sla 1
icmp-echo 2.2.2.2 source-interface Loopback0
ip sla schedule 1 life forever start-time now
control-plane
banner exec ^C
* IOSv is strictly limited to use for evaluation, demonstration and IOS *
* education. IOSv is provided as-is and is not supported by Cisco's *
* Technical Advisory Center. Any use or disclosure, in whole or in part, *
* of the IOSv Software or Documentation to any third party for any *
* purposes is expressly prohibited except as otherwise authorized by *
* Cisco in writing. *
**************************************************************************^C
banner incoming ^C
banner login ^C
line con 0
line aux 0
line vty 0 4
password a
login
transport input none
no scheduler allocate
end
R1#
R1#sh ip int br
GigabitEthernet0/0 192.168.1.1 YES NVRAM up up
GigabitEthernet0/1 unassigned YES manual administratively down down
GigabitEthernet0/2 unassigned YES NVRAM up up
GigabitEthernet0/3 unassigned YES NVRAM up up
Loopback0 1.1.1.1 YES NVRAM up up
R1#
R2#sh run
Current configuration : 3132 bytes
! Last configuration change at 09:33:48 UTC Tue Aug 2 2022
version 15.6
hostname R2
boot-start-marker
boot-end-marker
enable secret 5 $1$vD0N$Qlg/3cOsgyJ5uyvte1WMl.
enable password a
no aaa new-model
ethernet lmi ce
no mmi pvc
ip cef
no ipv6 cef
redundancy
interface Loopback0
ip address 2.2.2.2 255.255.255.255
ip address 192.168.1.2 255.255.255.0
duplex auto
speed auto
media-type rj45
ip address 192.168.2.1 255.255.255.0
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
no ip address
duplex auto
speed auto
media-type rj45
no mop enabled
no ip http server
control-plane
banner exec ^C
banner incoming ^C
banner login ^C
line con 0
line aux 0
line vty 0 4
password a
login
end
R2#
R2#sh ip int br
GigabitEthernet0/0 192.168.1.2 YES NVRAM up up
GigabitEthernet0/1 192.168.2.1 YES NVRAM up up
GigabitEthernet0/2 unassigned YES NVRAM administratively down down
Loopback0 2.2.2.2 YES NVRAM up up
R2#
can  you test in your lab?
Your config is correct, but unfortunately IP SLA not work when source-interface or source-ip is LOOPBACK.
I check this point.
and I do lab also there is no ICMP packet from R1 toward R2.
sorry you need to change the source.
Since there is no any mention in Cisco about this point I do small lab but with new idea,
and it work using IP SLA with LO is work only if the track is not use for static route of IP SLA destination.
THIS WORKAOUND I NOT RECOMMEND.
Maxizman
Visitor
Try to specify the frequency in SLA config.
