02-19-2011 11:35 AM - edited 03-04-2019 11:29 AM
I have a network architecture like the one HERE but with alot more spokes (32). Would my cisco 3925 be able to support so many crypto maps?
Solved! Go to Solution.
02-19-2011 02:38 PM
I thinking you are asking that how many crypto peers would your router be able to support right ? , you can use the following command to see how many Max IKE , DH & IPsec sessions your device can handle at a time :-
router# sh crypto eli
This will tell you active sessions you have and how many your device can support.
Manish
02-19-2011 02:38 PM
Manish
02-19-2011 02:51 PM
thanks a lot! i will try first thing in the morning!
