How many Vpns can I configure in 2900 series routers?
vulatec89
Beginner
Beginner
Somebody knows, what is the maximum number of Lan-to-Lan and user vpns supported in the ISR G2 2911 and 2921?
No problem at all.
Routers of 10 years ago could do that.
5 Replies 5
paolo bevilacqua
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
How many do you need ?
vulatec89
Beginner
Beginner
Approximately I need between 50 and 60 user VPNs and 1 to 5 Lan-to-Lan Vpns
No problem at all.
Ok thanks.
manish arora
Frequent Contributor
I agree with Paolo but you can always use "show crypto eli" and check for max supported IKE , DH & ipsec sessions.
Manish
