Highlighted
Enthusiast
How "low latency work"? Anyone can explain?
How "low latency" work? How to configure it? Anyone can explain briefly by an example or send a link? Thank you
2 REPLIES 2
Highlighted
VIP Expert
latency basically equals delay. The link below is a good start:
Latency in a nutshell, and what makes it so important
https://www.excentis.com/blog/latency-why-important
Highlighted
VIP Expert
Could you expand a bit upon your questions?  Reason I ask, latency doesn't so much "work", as it's just is (although there are different "causes" of latency).  Further, you don't generally configure it, except, perhaps, in cases where you're doing some form of test and you're trying to create an environment that will match/mimic some other environment.
