How to Block Torrent traffic on ASA 5510 Details inside thanks
Lost & Found
Level 2
Level 2
Good day
I would like to ask how to block torrent traffic on asa 5510?
I tried to this config. but didn't work. any idea??
object-group service Blocked-UDP-Ports udp
description All ports blocked for Bit Torrent UDP
port-object range 10001 65535
port-object range 1024 1193
port-object range 1195 9999
object-group service BitTorrent-Tracker tcp
description TCP Ports used by Bit Torrent for tracker communication
port-object eq 2710
port-object range 6881 6999
access-list inside_access_in extended deny udp any any object-group Blocked-UDP-Ports log warnings inactive
access-list inside_access_in extended deny tcp any any object-group BitTorrent-Tracker log warnings inactive
Thank you in advance
kennepha
arvin_robel1,
Torrent clients will use random ports, so blocking specific ports will be an insufficient solution to deny all torrent traffic.
A search on the supportforums reveals another question similar to yours in which the recommended solution is to use MPF or NBAR (https://supportforums.cisco.com/discussion/11732491/blocking-torrents-asa)
However, with some of the technology that torrent clients provide such as encryption or header spoofing, it may still prove to be difficult to block torrent traffic via those methods. If you must absolutely block all torrent traffic, creating a whitelist for approved traffic may be your best bet.
-- Kenneth
