how to check 16GB memory on asr1002X
adam.king1
We purchase a asr1002X with 16GB memory but after install 4GB*4 in to asr the show version still appear 8GB memory.
how to check 16GB on asr1002X?
Thank you ..
Can check 16GB memory at show version,
16777216K bytes of physical memory.
7 Replies 7
did you install all 4 modules at the same time ? Do all 4 modules have the same part number ?
http://www.cisco.com/c/en/us/td/docs/routers/asr1000/install/guide/asr1routers/asr1higV8/asr1FRUs.html#46186
Yes, install all 4 modules at the same time and all 4 modules have the same part number that purchased from cisco M-ASR1002X-16GB ..
The show informations after install M-ASR1002X-16GB as following,
Cisco IOS XE Software, Version 03.16.02b.S - Extended Support Release
Cisco IOS Software, ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S2b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Sat 21-May-16 09:07 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2016 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BGPASR1002X-DR uptime is 28 minutes
Uptime for this control processor is 29 minutes
System returned to ROM by reload at 12:36:23 UTC Sat Jan 21 2017
System image file is "bootflash:/asr1002x-universalk9.03.16.02b.S.155-3.S2b-ext.SPA.b"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: adventerprise
License Type: Permanent
Next reload license Level: adventerprise
cisco ASR1002-X (2RU-X) processor (revision 2KP) with 6801461K/6147K bytes of memory.
Processor board ID FOX2042GL6B
6 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
6594559K bytes of eUSB flash at bootflash:.
MIDPLANE EEPROM data:
EEPROM version : 4
Compatible Type : 0xFF
Controller Type : 1818
Hardware Revision : 1.0
PCB Part Number : 73-13257-09
Board Revision : A0
Deviation Number : 0-0
Fab Version : 06
PCB Serial Number : JAE21010638
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Top Assy. Part Number : 68-3873-10
CLEI Code : CMMST00ARC
Product Identifier (PID) : ASR1002-X
Version Identifier (VID) : V06
Manufacturing Test Data : 00 00 00 00 00 00 00 00
Field Diagnostics Data : 00 00 00 00 00 00 00 00
Chassis MAC Address : 002c.c880.6c00
MAC Address block size : 256
Chassis Serial Number : FOX2042GL6B
Environment Monitor Data : 00 06 00 FA
Asset ID :
Power/Fan Module P0 EEPROM data:
EEPROM version : 1
Hardware Revision : 3.0
Version Identifier (VID) : V04
Product Identifier (PID) : ASR1002-PWR-AC
PCB Serial Number : DCB2101417K
Top Assy. Part Number : 341-00263-04
Board Revision : A0
Power Supply Type : AC
RMA History : 00
CLEI Code : COUPADUBAC
Unknown Field (type 00DA): 00 00 00 00 00 00 00 00
Platform features : 00 01 02 29 13 A3 09 D2
43
Asset ID :
Power/Fan Module P1 EEPROM data:
EEPROM version : 1
PCB Serial Number : DCB2101415D
Board Revision : A0
RMA History : 00
43
Asset ID :
Slot R0 EEPROM data:
EEPROM version : 4
Board Revision : A0
Fab Version : 06
RMA History : 00
Asset ID :
Asset ID :
Slot F0 EEPROM data:
EEPROM version : 4
Board Revision : A0
Fab Version : 06
RMA History : 00
Asset ID :
Asset ID :
Slot 0 EEPROM data:
EEPROM version : 4
Board Revision : A0
Fab Version : 06
RMA History : 00
Asset ID :
Asset ID :
SPA EEPROM data for subslot 0/0:
EEPROM version : 4
Controller Type : 1824
Boot Timeout : 400 msecs
PCB Serial Number :
PCB Part Number : 73-12812-01
PCB Revision :
Fab Version : 01
RMA History : 00
Product Identifier (PID) : 6XGE-BUILT-IN
Version Identifier (VID) : V00
Top Assy. Part Number : 68-3044-02
Top Assy. Revision :
IDPROM Format Revision : 36
System Clock Frequency : 00 00 00 00 00 00 00 00
00 00 00 00 00 00
CLEI Code :
Base MAC Address : 00 00 00 00 00 00
MAC Address block size : 0
Calibration Data : Minimum: 0 dBmV, Maximum: 0 dBmV
Calibration values :
Power Consumption : 13100 mWatts (Maximum)
Environment Monitor Data : 03 30 00 00 00 00 00 00
00 00 FE 02 FE CD
Processor Label : 00 00 00 00 00 00 00
Platform features : 00 00 00 00 00 00 00 00
Asset ID :
Asset Alias :
SPA EEPROM data for subslot 0/1 is not available
SPA EEPROM data for subslot 0/2 is not available
SPA EEPROM data for subslot 0/3 is not available
I would remove two of the modules and check if memory is still the same, then insert the ones you removed, and remove the two other ones. This way, you can at least check if they all work.
Thank you ..
so now you can see all the 16GB ?
This is what you had previously, what is the output of 'show version' now ?
Adam
For platforms that use IOS-XE, show ver (unlike IOS) shows physical DRAM which is the total DRAM installed in this router, in addition to what is available (assigned actually) for IOS to use.
You will never find a situation where the physical DRAM matches what is allocated for IOS's use.
From your example, physical DRAM is
Total DRAM is 16777216K. Of this, IOS has been assigned 6801461K for processor pool and and 6147K for IO. Inspect the output of show run | sec redundancy
Here, if you see <mode sso> is configured, you have two software instances of IOS-XE running. If you change this to <mode none>, then you will see the allocation for IOS (processor pool) go up significantly but still be under total/physical DRAM.
I hope this helps .... Palani
Hi Panni,
Can you help me please?
I have the same issue. But I'm unable to view 6.5gb of processor memory. Is that due to license issue or?
Redundancy mode is none.
cisco ASR1002-X (2RU-X) processor (revision 2KP) with 3422740K/6147K bytes of memory.
Processor board ID
6688767K bytes of eUSB flash at bootflash:.
