How to Check Throughput License of ASR 1002x
ahmad82pkn
Level 3
Level 3
hi all, i  have ASR 1002x, i want to know if i am running at 2.5Gbps default  throughput or  5Gbps throughput ?
can i find it somehow?
Vinit Jain
Hello
You can verify this by using hte command "show platform hardware throughput level".
To change the throughput, use the below configuration (assuming you have the correct license installed
Router>enable
Router#configure terminal
Router(config)#platform hardware throughput level 5000000
% The config will take effect on next reboot
Router(config)#exit
Router#copy running-config startup-config
Router#reload
Hope this answers your questions.
Vinit
--Vinit
Vinit Jain
Hello
Router>enable
Router(config)#exit
Router#reload
Vinit
--Vinit
thank you Vinit.
