06-20-2005 08:37 PM - edited 03-03-2019 09:51 AM
I have Farme relay connection between 2 sites with a static link, Now We Want to change from Frame Relay to Lease line link. can you help in how to config this changes, We are using cisco routers in both ends.
Thank your help.
AT
Solved! Go to Solution.
06-21-2005 12:24 AM
Hi!
The only difference is the packet encapsulation. Instead of using Frame Relay, you can now use point-to-point protocol. Not much of a difference in the configuration.
Router A
interface Serial0/0
ip address x.x.x.1 255.255.255.252
encapsulation ppp
Router B
interface Serial0/0
ip address x.x.x.2 255.255.255.252
encapsulation ppp
then just add the static routes or dynamic routes whichever you prefer.
For more information on ppp, check out this link:
Hope this helps!
Albert Ü
06-21-2005 12:24 AM
Hi!
Router A
interface Serial0/0
encapsulation ppp
Router B
interface Serial0/0
encapsulation ppp
Hope this helps!
Albert Ü
06-21-2005 02:24 AM
Hi AT,
Even you need not configure PPP as you have cisco routers on both the sides.
Just take out the config for frame relay encapsulation and it will work on default encapsulation which is HDLC which is perfect for lease lines.
Ankur
