Highlighted
Beginner
How to delete a IP SLA rtr configuration on Cisco2801
Hi all,
i have a Cisco 2801 (Cisco IOS Software, 2801 Software (C2801-ADVSECURITYK9-M), Version 12.4(3h) with 99% CPU load.
When i check the process the load is caused by:
63  12227234801818196819        672 98.77% 98.19% 98.32%   0 IP SLA Mon Event
i assume this has something to do with our Cisco works IPM configuration.
to verify i checked the the rtr config on the router.
I see three rtr configurations pointing to our cisco works device.
On IPM there seems no (more) collector configured with these names.
Now i want to know:
1.
How can i delete the rtr configuration from the router, to make sure that CPU will decline?
2.
Is the CPU load caused by this rtr configs, especially cause of the missing collectors on the IPM configurations.
here you find the rtr configs:
R_MX_BU#sh rtr config
SA Agent, Infrastructure Engine-II
Entry number: 150509
Owner: ipm|sdeu1120
Tag: CCA_SAP_MX2
Type of operation to perform: tcpConnect
Target address: 10.24.14.104
Source address: 172.16.96.8
Target port: 3299
Source port: 12883
Operation timeout (milliseconds): 6000
Type Of Service parameters: 0x20
Control Packets: disabled
Operation frequency (seconds): 61
Next Scheduled Start Time: Start Time already passed
Group Scheduled : FALSE
Life (seconds): Forever
Entry Ageout (seconds): 3600
Recurring (Starting Everyday): FALSE
Status of entry (SNMP RowStatus): Active
Threshold (milliseconds): 1000
Number of statistic hours kept: 2
Number of statistic distribution buckets kept: 1
Statistic distribution interval (milliseconds): 20
Number of history Lives kept: 0
Number of history Buckets kept: 15
History Filter Type: None
Enhanced History:
Entry number: 164364
Owner: ipm|sdeu1120
Tag: CCA_DC_LDAP_MX2
Target address: 172.16.65.10
Target port: 389
Source port: 32797
Operation timeout (milliseconds): 60000
Type Of Service parameters: 0x0
Threshold (milliseconds): 200
Enhanced History:
Entry number: 213014
Owner: ipm|sdeu1120
Tag: CCA_DNS_MX2
Type of operation to perform: dns
Target address: vdedns01.de.festo.net
Source port: 0
Operation timeout (milliseconds): 9000
Threshold (milliseconds): 5000
Everyone's tags (4)
2 REPLIES 2
Highlighted
Beginner
Re: How to delete a IP SLA rtr configuration on Cisco2801
I have the same problem! Have you been able to remove the configuration of RTR?
Thanks and Regards!
Highlighted
Beginner
how can i used the ipm to monitor the network device?
the device must the porper IOS or others?
