208
Beginner
How to disable VTP on cisco 2811 router
Hi All,
How to disable VTP on cisco 2811 router.
We needs to remove VTP.
6 REPLIES 6
VIP Mentor
Re: How to disable VTP on cisco 2811 router
what are you trying to accomplish ? There is nothing VTP related on a 2811 router...
VIP Advisor
VTP only be available in the Cisco Switches,
BB
*** Rate All Helpful Responses ***
Hall of Fame Community Legend
The guys are correct.  Routers don't "understand" VTP, HOWEVER, does the router have a switch module installed?
VIP Expert
I was wondering the same. I recall(?) those (model specific?) may support VTP.
Rising star
if the router has a switch module, you can try the "no switchport" command on the interface
VIP Expert
That would only work, I believe, on L3 capable switch modules. It would also turn the port into a routed port.
BTW, I also recall (?), VTP should only be active on trunk ports.
Lastly, on some routers with integrated LAN ports (e.g. 800 series), I also recall (?) some of the LAN related commands are a bit different in syntax from other switches.
Content for Community-Ad
July's Community Spotlight Awards
