How to implement VPN
Abdulkader Naji
I have to sites A and B .the Site A have router connected to ADSL Modem for internet connection and Site B has the same but I have Public IP on Site B Modem.
Now I want to make the two network connected to each other with all feature .
I read alot about VPN Site to Site but not sure what is the suitable configuration.
Site A Router Model 2800 and the other Site B Model 2800.
What do you suggest.
Mark Malone
Hi a lan-lan IPsec tunnel would do as an option , quite easy to setup as well
here's 2 good docs explain it will , just create IPsec and tunnel and then apply acl to allow what you want down tunnel
Have your modems in bridge mode so public ip terminates on Cisco gear to form tunnel
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-routers/867-cisco-router-site-to-site-ipsec-vpn.html
http://www.cisco.com/c/en/us/support/docs/routers/1700-series-modular-access-routers/71462-rtr-l2l-ipsec-split.html
the cisco router has static router to the ADSL Router and NAT happens at ADSL Modem not the cisco router in this case what I have to change on the configuration.
The nat would need to be on the Cisco router not the modem as the modem needs to be in bridge mode so the public ip is available on it for the ipsec
so you need to configure the Cisco router for nat
Example
http://www.cisco.com/c/en/us/support/docs/security-vpn/ipsec-negotiation-ike-protocols/14132-ios-D.html
