how to make a backup copy of my router configuration
unidadso
how to make a backup copy of my router configuration cisco isr 1100
Martin L
3rd option I forgot is Putty logging of output. it is sort of automatic; it writes all command that u do in CLI.
see option in putty
after selecting options, go back to sessions and login .
after that, go back to Browse and look for your file. u can open in notepad
Regards, ML
**Please Rate All Helpful Responses **
8 Replies 8
Martin L
send configs to tftp server once per every week manually or using script.
1. manual
copy running-config tftp://<SERVER_IP>/<FILE_NAME/
2. Cisco IOS Auto Archive Feature was introduced into Cisco IOS Release 12.3(4), the Archive command enables the administrator to configure snapshots of the configuration files. (research archive command in Cisco Doc)
R1(config)#archive
R1(config-archive)#path tftp://172.16.1.10/
R1(config-archive)#time-period 10080
Regards, ML
I have 2 questions
when doing this process what type of extension is passed
and how the confiuration would be restored
advantages of doing it by ftp
and advantages pass it to a txt
advantages of doing it by tftp
-no mulitple copy and paste as u go and moving screen. if your config is long, u will not fit all of it on 1 screen.  plus, unless u modify windows registry to large scroll back,  info will be overwritten after few scrolls
advantages pass it to a txt  - are only simplicity and quickness if u have small show run.
Regards, ML
luis_cordova
Hi @unidadso ,
Another option:
Execute the command:
R# show running-config
Copy the entire result and paste it into a .txt
To return the settings, copy the entire .txt in global configuration mode:
R(config)#
Then, you just have to turn on all the configured interfaces:
R(config-if)#no shutdown
Is there a solution to prevent a config or list of commands from being messed up when I manually copy it to a router?
Martin L
see option in putty
Regards, ML
thanks this was what i needed
