03-24-2021 09:18 AM
How do i port forward a range of ports on my ASA Firewall?
Best Greetings Christian Josiassen
Solved! Go to Solution.
03-24-2021 09:33 AM
FYI : https://www.petenetlive.com/KB/Article/0001111
M.
03-24-2021 11:50 AM
Example as below :
object service My_Ports
service tcp source range 80 443 3389
object network Inside_Device
host 192.168.1.X
nat (inside,outside) source static Inside_Device interface service My_Ports My_Ports
if you are using ASDM you can below document :
03-24-2021 09:33 AM
M.
03-24-2021 11:50 AM
Example as below :
host 192.168.1.X
