How to setup Cisco 890 true webinterface
wesley
I have a Cisco 890 Router. But I lost the setup CD/DVD to configure my Cisco 890. Can somebody tell me
how I can access the webinterface or setup from this router. Or can I somewhere download the software?
Thx
On that picture you are the privileged exec mode, now you can configure the router executing configure terminal
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
81 Replies 81
Julio E. Moisa
Please check this link, basically it is the configuration used on the devices, now if you are going to use the local credentials created on the device you need to configure:
ip http authentication local
The Access-list can be optional.
http://www.cisco.com/c/en/us/td/docs/ios/12_2/configfun/configuration/guide/ffun_c/fcf005.html
Also I was reading you need at least this image installed on your device:
15.2(4)M2
or
15.3(1)T
Hope it is useful
I can access the interface via IP but it asks for username and password. These I don't know anymore. I already reset the router. Is there
any dafault username and password?
Kind Regards
Wesley
try:
Username: Admin
Password: none (that means empty)
or
Username: cisco
Password: cisco
or
Username: Cisco
Password: Cisco
doesn't work :(
I get this:
The server 192.168.1.100 is asking for your user name and password. The server reports that it is from level_15 or view_access
try 'username1' for both username and password...
no luck. Strange. Reset and still nothing
Type: cisco892w-agn-p-k9
try:
username1
password1
This is a one time username and password and needs to be changed after logging in...
also nothing. I dont know what could be the problem here with this router....
How do you reset the router ? With the reset button at the back ?
Unplug the router, push and hold the reset button while you plug the power cord back in. Continue holding the reset button for up to 30 seconds and let the router boot as normal.
have you tried:
admin
admin
Please check this link:
http://www.cisco.com/c/en/us/td/docs/routers/access/800/hardware/installation/guide/800HIG/initalconfig.html
If you have access via CLI, you can configure:
Example:
username Cisco Privi 15 password Cisco
enable secret Cisco
Now it is resetted correctly. Now I have IP 10.10.10.1
Gonna try now the basic username and password
Perfect, please keep us posted.
the following I get when login in to the router is:
Cisco CP Express requires at least Internet Explorer 5.5, Netscape Navigator 7.1,
or Firefox 1.0.2.
Your browser does not seem meet these requirements. (Netscape version 7.0)
You can continue, but proper functioning is not guaranteed.
Using: Explorer 11, also have Firefox and Edge. Chrome also not working.
When clicking OK nothing happens
Kind Regards
