how to use GUI interface
vipinyadav84
hi
pls tell me how to access gui interface of cisco 3845
desai.jaideep
Level 5
Level 5
Is GUI (SDM) already installed on your PC?
If its there then just connect pc to g0/0,set pc to obtain IP from DHCP and type https://10.10.10.1 in your browser.
If not the pls refer following link for installating/troubleshooting sdm config.
http://www.cisco.com/univercd/cc/td/doc/product/software/sdm/sdmqsg/sdmq21.htm
Do come back in case you find it difficult, and indicate the problem
JDHi
JD
