HSRP 2 ISP Scenario
Henry Martel
We have a customer who has a network consisting of two ISPs, one as a primary and the other as a backup. The customer would like us to use HSRP for the failover. The problem is the customer wants the configuration done with the two ISP routers connected to a 3550. He is under the impression that it can be done this way. ISP 1 []--------[_]3550------[] ISP2. From my understanding of HSRP can only be done with Cisco router and not ISP routers. Can this scenario be done?
mahmoodmkl
Level 7
Level 7
Can you please clarify what do u mean by ISP routers..?
If the 2 cisco routers are connected to a switch then HSRP is possible.
The two routers at the customer prem are non cisco routers. And from what i understand isn't HSRP is a ciso proprietary protocol?
if they are not cisco then u can consider vrrp for this
