HSRP Authentication.
atul_dalvi
Dear All,
Which one of the following is suitable AND BEST command for HSRP MD5 Authentication.
standby 1 authentication md5 key-chain
OR
standby 1 authentication md5 key-string
RanilG
Level 3
Level 3
In my opinion, one key-string is sufficient and simple.
Haven't used key-chains so far.However, if you think that you'd want to tighten up the security by allowing use of different key-strings at different times then key-chain is the choice.
