Highlighted
Beginner
HSRP for outside
I have 5 static IPs from ISP
I have two border routers. I want to run HSRP for outside.
R1: int gig 0/0   20.20.20.1 255.255.255.248
ip nat outside
ip route 0.0.0.0 0.0.0.0 20.20.20.6
R2: int gig 0/0   20.20.20.2 255.255.255.248
ip nat outside
ip route 0.0.0.0 0.0.0.0 20.20.20.6  10
R1 and R2: standby 1 ip 20.20.20.3
QUESTIONS:
how to set up nat so all outgoing traffic has source of 20.20.20.3
how to set up nat, so I can use rest of the IPs. (20.20.20.4, 20.20.20.5)
I want to host 2 different web servers on these IPs
I have anyconnect on 20.20.20.3
2 REPLIES 2
Highlighted
VIP Advisor
Re: HSRP for outside
With hsrp you can setup resilient nat.
Take a look at this document which explains it very well:
https://www.cisco.com/c/en/us/products/collateral/ios-nx-os-software/ios-software-releases-12-2-t/prod_white_paper0900aecd8052870b.html
What do you mean by:
You want to create static nat for these servers (1:1 nat)?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Highlighted
Firstly the IP 20.20.20.3 is an internal Lan IP which should not be the source IP for the outgoing packets.
   Not possible if you use PAT so that all the outgoing traffic takes outside interface IP
   You can use the rest of the IP's inside the LAN with no issues
      You can use these IP's in the LAN either in PC or servers doesnt matter, packets will be routed via the active router.
   Not sure about this , as you are using it as virtual IP, how you are expecting to configure same IP in the anycast.
Please do not hesitate to click the STAR button if you are satisfied with my answer.
