HSRP help
imunoze00
I'm trying to configure a couple of routers for HSRP functionality and this is all new to me. I has the chance to look at a config for the other router on the HRSP "cluster" or however you wanto to call it. I'm not entirely sure that the config is ok so any help will be much appreciated. Will post configs and diagram
This is the config for the main HSRP router (most left blue router):
class-map match-any DATOS-P2
match access-group name CLASE2
class-map match-any DATOS-P3
match access-group name CLASE3
class-map match-any DATOS-P4
match access-group name CLASE4
class-map match-any Precedencia3
match ip precedence 3
class-map match-all Precedencia2
match ip precedence 2
policy-map LAN
class DATOS-P3
  set ip precedence 3
class DATOS-P2
  set ip precedence 2
class class-default
  set ip precedence 1
policy-map WAN
class Precedencia3
  priority percent 25
  police cir 7500000 bc 125000 be 125000
    conform-action transmit
    exceed-action drop
class Precedencia2
  bandwidth percent 20
  queue-limit 4096
  police cir 6000000 bc 500000 be 500000
    exceed-action transmit
class DATOS-P4
  police cir 16500000 bc 1250000 be 1250000
    exceed-action drop
class class-default
  fair-queue
  queue-limit 4096
interface Tunnel0
description INTERFACE PARA DETECTAR LA CAIDA DEL L2L
ip address 170.100.100.1 255.255.255.252
keepalive 3 2
tunnel source GigabitEthernet0/1
tunnel destination 192.168.112.2
interface GigabitEthernet0/0
description CONEXION A LA WAN-ROUTER DF INFONAVIT Fe0/0
bandwidth 30000
ip address 201.161.31.249 255.255.255.252 secondary
ip address 10.0.0.1 255.255.255.252
ip accounting output-packets
load-interval 30
duplex full
speed 100
no cdp enable
max-reserved-bandwidth 100
service-policy output WAN
interface GigabitEthernet0/1
description CONEXION A LA LAN MUNOZ LEON SWITCH CATALYST 3750 PTO 1
ip address 201.161.31.254 255.255.255.252 secondary
ip address 172.31.47.252 255.255.255.0
no ip proxy-arp
duplex full
speed 100
no cdp enable
standby 1 ip 172.31.47.254
standby 1 timers 5 10
standby 1 priority 105
standby 1 preempt delay minimum 5
standby 1 track Tunnel0
service-policy input LAN
ip classless
ip route 0.0.0.0 0.0.0.0 172.31.47.253 name MONITOREO-EQUIPOS-MAXCOM
ip route 10.90.0.0 255.255.255.0 10.0.0.2 name RED-INFONAVIT-10
ip route 10.90.1.0 255.255.255.0 10.0.0.2 name RED-INFONAVIT-1
ip route 10.90.8.0 255.255.255.0 10.0.0.2 name RED-INFONAVIT-2
ip route 10.90.124.0 255.255.255.0 10.0.0.2 name RED-INFONAVIT-9
ip route 10.100.1.0 255.255.255.0 10.0.0.2 name RED-INFONAVIT-3
ip route 10.100.4.0 255.255.255.0 10.0.0.2 name RED-INFONAVIT-4
ip route 172.17.0.0 255.255.0.0 10.0.0.2 name RED-INFONAVIT-5
ip route 172.17.6.242 255.255.255.255 172.31.47.253 name EQUIPO-PRUEBAS
ip route 192.168.107.0 255.255.255.0 10.0.0.2 name RED-INFONAVIT-6
ip route 192.168.108.0 255.255.255.0 10.0.0.2 name RED-INFONAVIT-7
ip route 192.168.112.0 255.255.255.252 10.0.0.2 name RED-INFONAVIT-8
ip route 201.161.6.40 255.255.255.255 201.161.31.253 name MONITOREO-ENLACEMAX-30
MBPS
no ip http server
ip access-list extended CLASE2
permit ip 172.31.47.0 0.0.0.255 host 192.168.112.2
permit ip 172.31.47.0 0.0.0.255 host 10.90.1.37
permit ip 172.31.47.0 0.0.0.255 host 10.90.1.38
permit ip 172.31.47.0 0.0.0.255 host 10.90.1.39
permit ip 172.31.47.0 0.0.0.255 host 10.90.1.168
permit ip 172.31.47.0 0.0.0.255 host 10.90.1.141
permit ip 172.31.47.0 0.0.0.255 host 10.90.1.20
permit ip 172.31.47.0 0.0.0.255 host 10.90.1.187
permit ip 172.31.47.0 0.0.0.255 host 10.90.0.200
permit ip 172.31.47.0 0.0.0.255 host 10.90.0.115
permit ip 172.31.47.0 0.0.0.255 host 10.90.0.107
permit ip 172.31.47.0 0.0.0.255 host 10.90.0.130
permit ip 172.31.47.0 0.0.0.255 host 10.100.4.83
permit ip 172.31.47.0 0.0.0.255 host 172.17.5.28
permit ip 172.31.47.0 0.0.0.255 host 10.100.4.130
permit ip 172.31.47.0 0.0.0.255 host 10.100.4.131
permit ip 172.31.47.0 0.0.0.255 192.168.107.0 0.0.0.255
permit ip 172.31.47.0 0.0.0.255 192.168.108.0 0.0.0.255
permit ip 172.31.47.0 0.0.0.255 host 10.90.0.85
permit ip host 172.16.4.100 any
ip access-list extended CLASE3
permit tcp any any eq 1720
permit udp any any range 16384 32767
ip access-list extended CLASE4
permit ip 172.31.47.0 0.0.0.255 host 10.100.4.132
This is the config for grayed out router on the left:
hidekeys
policy-map LAN
class DATOS-P3
  set ip precedence 3
class DATOS-P2
  set ip precedence 2
class class-default
  set ip precedence 1
policy-map WAN
class Precedencia3
    priority percent 25
     exceed-action drop
class Precedencia2
    queue-limit 4096 packets
class DATOS-P4
     exceed-action drop
class class-default
    fair-queue
interface Tunnel0
ip address 170.100.101.1 255.255.255.252
keepalive 3 2
tunnel source FastEthernet0/1
tunnel destination 192.168.114.2
interface FastEthernet0/0
description // WAN INFONAVIT //
ip address 10.1.1.1 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1
description // LAN INTERFACE //
ip address 172.31.47.251 255.255.255.0
duplex auto
speed auto
standby 1 priority 90
interface Serial0/0/0
no ip address
shutdown
clock rate 2000000
no ip forward-protocol nd
ip route 10.90.0.0 255.255.255.0 10.1.1.2 name RED-INFONAVIT-10
ip route 10.90.1.0 255.255.255.0 10.1.1.2 name RED-INFONAVIT-1
ip route 10.90.8.0 255.255.255.0 10.1.1.2 name RED-INFONAVIT-2
ip route 10.90.124.0 255.255.255.0 10.1.1.2 name RED-INFONAVIT-9
ip route 10.100.1.0 255.255.255.0 10.1.1.2 name RED-INFONAVIT-3
ip route 10.100.4.0 255.255.255.0 10.1.1.2 name RED-INFONAVIT-4
ip route 172.17.0.0 255.255.0.0 10.1.1.2 name RED-INFONAVIT-5
ip route 192.168.107.0 255.255.255.0 10.1.1.2 name RED-INFONAVIT-6
ip route 192.168.108.0 255.255.255.0 10.1.1.2 name RED-INFONAVIT-7
ip route 192.168.112.0 255.255.255.252 10.1.1.2 name RED-INFONAVIT-8
no ip http server
permit ip 172.31.47.0 0.0.0.255 host 192.168.114.2
This is the config for grayed out router on the right:
ip subnet-zero
no ip routing
no ip cef
no ftp-server write-enable
controller E1 0/1
policy-map LAN
  class DATOS-P3
   set ip precedence 3
  class DATOS-P2
   set ip precedence 2
  class class-default
   set ip precedence 1
policy-map WAN
  class Precedencia3
   priority percent 25
     exceed-action drop
  class Precedencia2
   police cir 18000000 bc 500000 be 500000
     exceed-action set-prec-transmit 1
   bandwidth percent 50
   queue-limit 96
  class class-default
   fair-queue
   queue-limit 4096
interface Tunnel0
ip address 170.100.101.2 255.255.255.252
keepalive 3 2
tunnel destination 172.31.47.251
description // WAN INTERFACE //
ip address 10.1.1.2 255.255.255.252
no ip route-cache
duplex auto
speed auto
no mop enabled
interface Serial0/0
no ip address
no ip route-cache
shutdown
ip address 192.168.114.2 255.255.255.252
no ip route-cache
duplex auto
speed auto
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.114.1
ip route 10.90.0.0 255.255.255.0 192.168.114.1 name RED-INFONAVIT-9
ip route 10.90.1.0 255.255.255.0 192.168.114.1 name RED-INFONAVIT-1
ip route 10.90.8.0 255.255.255.0 192.168.114.1 name RED-INFONAVIT-2
ip route 10.90.124.0 255.255.255.0 192.168.114.1 name RED-INFONAVIT-8
ip route 10.100.1.0 255.255.255.0 192.168.114.1 name RED-INFONAVIT-3
ip route 10.100.4.0 255.255.255.0 192.168.114.1 name RED-INFONAVIT-4
ip route 172.16.4.31 255.255.255.255 10.0.0.1 name RED-MUNOZ-4
ip route 172.16.4.100 255.255.255.255 10.0.0.1 name RED-MUNOZ-3
ip route 172.17.0.0 255.255.0.0 192.168.114.1 name RED-INFONAVIT-5
ip route 172.17.6.242 255.255.255.255 10.0.0.1 name EQUIPO-PRUEBAS-MUNOZ
ip route 172.31.47.0 255.255.255.0 10.0.0.1 name RED-MUNOZ-1
ip route 172.31.48.0 255.255.255.0 10.0.0.1 name RED_KAPPA_DRP
ip route 192.168.107.0 255.255.255.0 192.168.114.1 name RED-INFONAVIT-6
ip route 192.168.108.0 255.255.255.0 192.168.114.1 name RED-INFONAVIT-7
no ip http server
permit ip host 192.168.114.2 172.31.47.0 0.0.0.255
permit ip host 10.90.1.37 172.31.47.0 0.0.0.255
permit ip host 10.90.1.38 172.31.47.0 0.0.0.255
permit ip host 10.90.1.39 172.31.47.0 0.0.0.255
permit ip host 10.90.1.168 172.31.47.0 0.0.0.255
permit ip host 10.90.1.141 172.31.47.0 0.0.0.255
permit ip host 10.90.1.20 172.31.47.0 0.0.0.255
permit ip host 10.90.1.187 172.31.47.0 0.0.0.255
permit ip host 10.90.0.200 172.31.47.0 0.0.0.255
permit ip host 10.90.0.115 172.31.47.0 0.0.0.255
permit ip host 10.90.0.107 172.31.47.0 0.0.0.255
permit ip host 10.90.0.130 172.31.47.0 0.0.0.255
permit ip host 10.100.4.83 172.31.47.0 0.0.0.255
permit ip host 172.17.5.28 172.31.47.0 0.0.0.255
permit ip host 10.100.4.130 172.31.47.0 0.0.0.255
permit ip host 10.100.4.131 172.31.47.0 0.0.0.255
permit ip host 10.100.4.132 172.31.47.0 0.0.0.255
permit ip 192.168.107.0 0.0.0.255 172.31.47.0 0.0.0.255
permit ip 192.168.108.0 0.0.0.255 172.31.47.0 0.0.0.255
permit ip host 10.90.0.85 172.31.47.0 0.0.0.255
permit ip host 192.168.114.2 172.31.48.0 0.0.0.255
permit ip host 10.90.1.37 172.31.48.0 0.0.0.255
permit ip host 10.90.1.38 172.31.48.0 0.0.0.255
permit ip host 10.90.1.39 172.31.48.0 0.0.0.255
permit ip host 10.90.1.168 172.31.48.0 0.0.0.255
permit ip host 10.90.1.141 172.31.48.0 0.0.0.255
permit ip host 10.90.1.20 172.31.48.0 0.0.0.255
permit ip host 10.90.1.187 172.31.48.0 0.0.0.255
permit ip host 10.90.0.200 172.31.48.0 0.0.0.255
permit ip host 10.90.0.115 172.31.48.0 0.0.0.255
permit ip host 10.90.0.107 172.31.48.0 0.0.0.255
permit ip host 10.90.0.130 172.31.48.0 0.0.0.255
permit ip host 10.100.4.83 172.31.48.0 0.0.0.255
permit ip host 172.17.5.28 172.31.48.0 0.0.0.255
permit ip host 10.100.4.130 172.31.48.0 0.0.0.255
permit ip host 10.100.4.131 172.31.48.0 0.0.0.255
permit ip host 10.100.4.132 172.31.48.0 0.0.0.255
permit ip 192.168.107.0 0.0.0.255 172.31.48.0 0.0.0.255
permit ip 192.168.108.0 0.0.0.255 172.31.48.0 0.0.0.255
permit ip host 10.90.0.85 172.31.48.0 0.0.0.255
9 Replies 9
This is basically what you need to join an HSRP group:
standby 1 ---> "1" is the specific HSRP group number.
standby 1 priority 105 ---> The priority indicates whether this device may become the "Active" unit, the highest priority wins the election.
standby 1 track Tunnel0 ---> If tunnel0 comes down the priority is = 105 - 10
HSRP Features
Yo hablo español y no tengo ningún problema en darte una mano con este post en Español.
Portu.
Please rate any helpful posts
so basically it should work the way it is configured right now, am I right?
The settings on this Router are OK, assuming the other one is properly configured, you should be in good shape.
Let me know if your have any other questions, otherwise please mark this post as answered.
Thanks.
Portu.
Well, the config for the other router for the HSRP functionality is this:
interface Tunnel0
keepalive 3 2
duplex auto
speed auto
duplex auto
speed auto
So lets just hope everything works OK once they're both plugged in later today, or tonight.
Sounds good.
Portu.
mlund
Level 7
Level 7
I have one notice to this.
As Portu already has pointed out, the track command decreases the priority with 10.
This means that if tunnel0 goes down the priority will be 105 -10 = 95
95 is still higher than the second routers configured priority that is 90, which leads to the fact that the primary router is still tha active one.
If the goal is that the second router shall take over in case of tunnelfailure on the primary router, then my suggesstion is that You configure the secoond router with priority 100 ( wich actually is the default value ).
/Mikael
I didn't know that, the 10 point deduction on failure. So I'll just have to configure the routers to have a 5 point spread and should do it.
Thanks for the input Mikael, I appreciate it !!
Let us know how it goes!
edward237
There is a mistake on the hsrp config
priority 105
and the other is
priority 90
the default valeu is 10
so, 105 - 10 = 95
95 > 90
so, there is no convergence between the routers.
my suggestion
set the Active router with priority 105 and the Standby let the default(100)
as the decrement is 10 by default, it will converge.
