HSRP Issue
kzhen
Below is the switch diagram. As you can see, sw01 is directly connected to SW02 and sw02 is also connected to SW03.
SW01 <-----> SW02 <----> SW03
Each switch has three VLAN's.
SW01: VLAN1: 10.10.1.1 , VLAN2:10.10.2.1 and VLAN3: 10.10.3.1
SW02: VLAN1: 10.10.1.2 , VLAN2: 10.10.2.2 and VLAN3: 10.10.3.2
SW03: VLAN1: 10.10.1.3 , VLAN2: 10.10.2.3 and VLAN3: 10.10.3.3
I have two questions about HSRP.
1. Can I run HSRP for VLAN 2 on three switches?
2. Can I run HSRP for VLAN2 on Sw01 and SW03 even thought they are not directly connected each other?
Please advise.
Mohamed Sobair
Level 7
Level 7
1- Yes you can.
2- Yes you can as long as they have IP reachability.
Mohamed
Ganesh Hariharan
Please advise.
You can run HSRP for vlan 2 on three switches and also you can run HSRP on sw1 and sw3 till you have reachablity of the interface ip's of the switches.
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_configuration_example09186a0080094e90.shtml
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
