HSRP ISSUE
aprasad11
Hi Guys,
Requesting for your assistance. I have a issue with HSRP. Despite having R1 Priority lower than R2. R1 does not become the standby router.
Below is show outputs.  The flash i am using is c880data-universalk9-mz.150-1.M5.bin. Probably a IOS bug?
R1
show standby brief
P indicates configured to preempt.
Interface Grp Pri P State Active Standby Virtual IP
Fa4.846 1 150 P Init unknown unknown 202.151.24.124
Fa4.4091 255 150 P Init unknown unknown 10.150.194.51
Vl10 1 95 P Active local 10.10.0.2 10.10.0.1
Vl20 2 85 P Active local 10.20.0.2 10.20.0.1
Vl30 3 85 P Active local 10.30.0.2 10.30.0.1
Vl100 4 85 P Active local 10.100.0.2 10.100.0.1
R2
Fa4.846 1 100 P Active local unknown 202.151.24.124
Fa4.4091 255 100 Active local unknown 10.150.194.51
Vl10 1 100 Standby 10.10.0.3 local 10.10.0.1
Vl20 2 100 Standby 10.20.0.3 local 10.20.0.1
Vl30 3 100 Standby 10.30.0.3 local 10.30.0.1
Vl100 4 100 Standby 10.100.0.3 local 10.100.0.1
Your configuration of R1 shows a priority of 105 but you are tracking an interface and the output of "sh standby brief" shows a priority of 95.
So do you mean R1 is still active when the tracked interface goes down ?
If so this is because you have not configured preempt on R2 and without that R2 will not take over even with a higher priority.
Jon
6 Replies 6
Mark Malone
hi
are these directly connected router to router interfaces or through a layer 2 switch ?
can you post the running config of the hsrp off each router please and if there is a switch involved make sure there is no acl blocking hsrp multicast address and that stp is not blocking at layer 2 in the path the failover takes
Hi Mark,
They are connected via  a layer 2 switch. There are acl in layer 2 switch
R1 config
interface Vlan10
ip address 10.10.0.3 255.255.255.0
ip nat inside
ip virtual-reassembly
standby 1 ip 10.10.0.1
standby 1 priority 105
standby 1 preempt delay reload 60 sync 15
standby 1 name test
standby 1 track 1 decrement 10
#show standby brief
R1
R2 Config
interface Vlan10
ip address 10.10.0.2 255.255.255.0
ip nat inside
standby 1 name test
R2
show standby brief
what is the acl in place doing ?
Is there only 1 layer 2 switch connected to each router 1 link  ?
is it Vlan 10 that's not working as it looks correct , Router 1 is currently active and router 1 is standby ?
Hi ,
Issue was on preempt
Jon
thanks John. yes preempt was the issue.
