HSRP Layout
rumhyvarghese
Good day,
Is it possible to implement HSRP with 2 routers and one switch?
R1 R2
Switch
LAN
Please advice
Sam Varghese
15 Replies 15
mheusinger
Level 10
Level 10
yes, this is the typical setup. make sure both routers are in the same VLAN and everything should go smoothly.
Hope this helps!
Regards, Martin
Wilson Samuel
Level 7
Level 7
Hi Sam,
One a typical / basic setup you require atleast 2 routers to begin with for a HSRP setup, hence you are all set to start with..
All the best!!
Wilson Samuel
Hi Sam,
you can run HSRP between the two routers with mask of /21 and in same vlan then on the switch you can point the default route to the standby IP.
regards
Mukesh
sdoremus33
Level 3
Level 3
Yes, just remember that the Virtual interface has the "same ip address, and that the routers is on the same subnet, with RouterA(Active), and RouterB(Preempt)HTH
Take care
Good day Sir,
Is it possible to use the same IP for the two routers in HSRP cluster? The default GW will be the new virtual IP address right?
Please advice,
Sam
minumathur
yes , it is possible, make sure, put default gate and as virtual IP address in switch, and make sure all are in same VLan.
Good Day
Is it possible to use same IP address for two routers in HSRP cluster? Will it work? I will make the default GW as the virtual IP..
Please advice
Rumhy
Hi Rumhy,
You have to use seperate ip in same subnet on 2 HSRP routers on their physical interfaces and then you can configure virtual ip address on both the interfaces which will be same on both the routers and also should belong to the same subnet as your phyical interface ip address.
Ankur
*Pls rate all helpfull post
Good day Sir,
Thanking you for your feedback. Our current network layout is attached. Please do check that & qoute in your comments
Best regards,
Sam
Switzerland
Yes You can use it.,,,
Whatever traffic is coming from firewall to routers you can use default gateway which is nothing but hsrp ip i.e cluster ip .
sample config:
R1 ---- switch----R2.
R1:
interface GigabitEthernet0/0
ip address 10.10.3.8 255.255.255.128
no ip unreachables
ip route-cache flow
duplex full
speed 1000
media-type rj45
no negotiation auto
no mop enabled
standby 2 ip 10.10.3.7
standby 2 priority 105
standby 2 preempt
and R2 router config:
description CONNECTED TO AND_CS01_HYD
ip address 10.10.3.9 255.255.255.128
no ip proxy-arp
duplex full
speed 1000
media-type rj45
no negotiation auto
standby 2 preempt
In the above case , suppose any user connected to firewall want to reach user connected in either R1 or R2 , you can use HSRP IP i.e 10.10.3.7 as a default gateway.
Satish
Thank you Sir
Best regards
Sam
maskmukesh
Dear Sam,
Hi iam sorry i did a mistake in my previos mail, the mask used should be /29 so that u will 6 ips and in which u can assign 1 IP to each of the int on router and 1 will be used for virtual(standby IP), 1 will be the vlan ip.
Good day Mr. Mukesh
Is it mandatory that I use a /29 mask for the HSRP routers? Our ISP came up with a suggestion of using /28 mask.
Please advice.
Best Regards,
Sam Varghese
System Engineer
SWITZERLAND
