HSRP object tracking
Andy White
Level 3
Level 3
I nornally track an interface line protocol when I set up HSRP, but today I noticed a router trackign "sla 1" what is this as there is no reference to it anywhere else in the config:
track 1 ip sla 1
interface GigabitEthernet0/1
ip address 172.30.22.10 255.255.255.0
standby 1 ip 172.30.22.1
standby 1 priority 110
standby 1 preempt
standby 1 track 1 decrement 10
duplex full
speed 100
7 Replies 7
Richard Burts
It has been my experience that tracking interface protocol works well when the interface is point to point serial but generally does not work well when the interface is Ethernet. There are lots of circumstances where you do not really have connectivity out the Ethernet interface but the interface line protocol is still up. So tracking some object is a way to detect whether the interface is really working. The syntax of configuring the track has changed a bit in various versions of IOS. I suspect that if you would post the complete config that we would be able to show you where the sla is configured.
Rick
Rick
Sure thing:
version 15.1
no service pad
service timestamps debug datetime
service timestamps log datetime
service password-encryption
hostname *
boot-start-marker
boot-end-marker
logging buffered 4096
enable secret
no aaa new-model
clock summer-time BST recurring last Sun Mar 2:00 last Sun Oct 3:00
no ipv6 cef
ip source-route
ip cef
ip flow-cache timeout active 1
login on-failure log
login on-success log
username *
track 1 ip sla 1
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
bandwidth 20000
ip address 172.118.33.42 255.255.255.252
ip flow ingress
ip flow egress
duplex full
speed 100
standby 1 ip 172.30.2.1
standby 1 preempt
duplex full
speed 100
router eigrp 191
network 172.118.33.40 0.0.0.3
network 172.30.22.0 0.0.0.255
network 172.30.102.0 0.0.0.255
redistribute static
ip forward-protocol nd
no ip http server
no ip http secure-server
ip flow-export source GigabitEthernet0/0
ip flow-export version 5
ip flow-export destination 192.168.1.249 9996
ip route 172.30.102.0 255.255.255.0 172.30.2.2
logging trap notifications
logging source-interface GigabitEthernet0/1
logging 192.168.8.129
access-list 23 permit 192.168.9.11
access-list 23 permit 172.118.33.40 0.0.0.3
access-list 64 permit 192.168.8.129
snmp-server community m0ghjr RO 64
control-plane
banner login ^C ########## WARNING - You must have authorisation to use this system. ##########
Unauthorised access to or misuse of this system constitutes a criminal offence under the 1990 Computer Misuse Act.
Use of the system may be logged without further notice and the resulting logs may be used as evidence in court.
^C
line con 0
password
login local
transport output all
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 23 in
exec-timeout 5 0
password
login local
transport input telnet
scheduler allocate 20000 1000
end
Hello Andy,
can you post output of #show track
I think that track 1 ip sla 1 is refering to not existing ip sla configuration, it would be probably some forgotten command after some change.
I assume that track state will be UP and it will not have any impact on HSRP.
Solution:
no track 1 ip sla 1
no standby 1 track 1 decrement 10
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
Here you go
#show track
Track 1
  IP SLA 1 state
  State is Down
    3 changes, last change 28w6d
  Latest operation return code: 8-8-8-8
  Tracked by:
    HSRP GigabitEthernet0/1 1
Thanks for posting the config. I was confident that we could show you where the object to track was configured. And I was wrong
It does look like there was object tracking configured at one time and that it has been removed.
Rick
Rick
@andy
SLA probes help track the interface in regard to FHRP's
even to track the redundant interfaces SLA's work as far as i know
the decreament helps to lower the priority of the down router so that the standby one can take over as active
Before any changes are made we should do a 'show standby'
Here we should be able to see the decrement of 10 from the original priority configured. Since Tracking is down state (because no ip sla is configured) this will be a good observation to make before any changes IMHO.
PS what happened 28 weeks ago, what were the configurations then and now. Can we compare?
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
