10-07-2013 07:57 AM - edited 03-04-2019 09:15 PM
I have some hosted servers in my network and internet users access them. last week my Router 3845 crashed and we had to faced 1 and hafl hour down time. i was reading about HSRP to make 2 router failover. my question is can we use HSRP for Internet users (Wan Link), and setup HSRP on 2 router with 1 ISP link on both router. if yes please give me clear example.
10-07-2013 08:20 AM
(R1)(R2)
(Switch)
( L A N ) (10.10.10.0/24)
So let's say you have VLAN 10 which is your data vlan.
R1
int x/x
ip address 10.0.0.2 255.255.255.0
standby 1 ip 10.0.0.1
standby 1 priority 101
standby 1 preempt
R2
int x/x
ip address 10.0.0.3 255.255.255.0
R1 will be the primary router, and if it goes down, R2 will take over. When R1 comes back online, It will have a higher priority of 101, and preempt configure, so it will preempt R2 from being Primary and move it to Secondary, and R1 will take over as primary.
Now, this is a very basic configuration. You can modify the times, and include a 'track' statement to track if an upstream interface went down. Because it should only change the primary by default, if the LAN interface for this particular standby goes own.
Please correct me if I'm wrong, if anyone else chimes in.
10-07-2013 08:57 AM
ok Thanks, what about Wan Link. can i use 1 ISP link on both router (attach cable in each router coming from same ISP).
10-07-2013 10:18 AM
Sorry, I actually ment to do that HSRP configuration for the WAN side. You would basically do the same thing except, different IPs for the WAN side. Obviously, always be sure to test before implementing anything in a production network.
10-07-2013 10:33 AM
Please correct me if i am wrong. how i connect 2 cables from same ISP.. will there be IP confilt ?
(R1)(R2)
( ISP )
R1
int x/x
standby 1 ip 50.200.X.X (IP from ISP)
standby 1 preempt
R2
int x/x
10-07-2013 11:51 AM
For starters, what is the WAN IP and network mask of your internet connection? You will need at least 3 IP addresses for this to work.
R1 and R2 will need to connect to a switch, where both ports going to R1 and R2 will be on the same VLAN. Then a port from the same VLAN as R1 and R2 will need to be connected to your ISP.
So let's say you have 20.20.20.0/29
(R1)(R2)
SW1
ISP
R1
int x/x
ip address 20.20.20.2 255.255.255.248
standby 1 ip 20.20.20.1
standby 1 preempt
R2
int x/x
ip address 20.20.20.3 255.255.25.248
The default route should be 20.20.20.1 which goes to your ISP. If you plan to implement a scenario like this, always test before implementation. You can use GNS3 to test out the configuration.
I got a turnup to do tonight, but if I have time, I'll try to post again if you reply.
10-25-2013 10:38 AM
Hi John,
my curreny config on both routers is 4 Vlans, IP SLA (ISP Fail Over) Site to Site and Site to Client VPN. please let me know what would be the configuration of HSRP on both routers with my current config.
10-25-2013 03:43 PM
Quasim,
This link below, should give you all the information you need.
http://www.ciscopress.com/articles/article.asp?p=766858&seqNum=4
11-04-2013 10:58 AM
I need to configure HSRP on WAN links, i am hosting servers (Web server, Citrix, App severs, etc). i have IPs from ISPs. I am also using IP SLA for Internet Failover on router. now i want to setup Routers failover using HSRP. my both routers config as below.
track 10 ip sla 1 reachability
delay down 1 up 1
track 20 ip sla 2 reachability
delay down 1 up 1
interface GigabitEthernet0/0
no ip address
ip virtual-reassembly in
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/0.7
description Voice-Vlan
encapsulation dot1Q 7
ip address 192.168.7.3 255.255.255.0
ip helper-address 192.168.10.15
ip helper-address 192.168.10.16
interface GigabitEthernet0/0.8
description IT-Vlan
encapsulation dot1Q 8
ip address 192.168.8.3 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.9
description Regency-Vlan
encapsulation dot1Q 9
ip address 192.168.9.3 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.10
description Servers-&-Switches-Vlan
encapsulation dot1Q 10
ip address 192.168.10.7 255.255.255.0
no ip redirects
no ip proxy-arp
ip nat inside
ip policy route-map PBR
interface FastEthernet0/0/1
ip address 50.x.x.14 255.255.255.252
ip nat outside
duplex full
speed 100
crypto map vpn
interface FastEthernet0/1/0
ip address 162.x.x.34 255.255.255.224
ip nat outside
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map ISP1 interface FastEthernet0/0/1 overload
ip nat inside source route-map ISP2 interface FastEthernet0/1/0 overload
ip nat inside source static tcp 192.168.10.53 80 50.x.x.52 80 route-map ISP1 extendable
ip nat inside source static tcp 192.168.10.53 80 162.x.x.35 80 route-map ISP2 extendable
ip route 0.0.0.0 0.0.0.0 50.x.x.13 track 10
ip route 0.0.0.0 0.0.0.0 162.x.x.62 200
ip access-list extended acl_internet
deny ip 192.168.0.0 0.0.255.255 10.10.10.0 0.0.0.255
deny ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
permit ip 192.168.0.0 0.0.255.255 any
ip access-list extended acl_natisp1
ip access-list extended acl_natisp2
ip access-list extended acl_ncsvpn
permit ip 192.168.0.0 0.0.255.255 192.168.4.0 0.0.0.255
ip access-list extended acl_vpn
permit ip 192.168.0.0 0.0.255.255 10.10.10.0 0.0.0.255
ip sla 1
icmp-echo 50.x.x.13
threshold 500
timeout 500
frequency 1
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 162.x.x.62
threshold 500
timeout 500
frequency 1
ip sla schedule 2 life forever start-time now
route-map PBR permit 10
match ip address acl_natisp1
set ip next-hop verify-availability 50.x.x.13 1 track 10
route-map PBR permit 20
match ip address acl_natisp2
set ip next-hop verify-availability 162.x.x.62 2 track 20
route-map ISP2 permit 20
match ip address acl_internet
match interface FastEthernet0/1/0
route-map ISP1 permit 10
match interface FastEthernet0/0/1
