HSRP subinterfaces problem
I have configured Router 1 as follows
int gi 0/0.10
encapsulation dot1q 10
ip add 192.168.10.3
standby 10 ip 192.168.10.1
standby 10 preempt
standby 10 priority 115
and Router 2 as
int gi 0/0.10
ip add 192.168.10.2
standby 10 preempt
They are connected via a switch to the LAN segment 192.168.10.0/24
A PC with
IP: 192.168.10.50
subnet: 255.255.255.0
default-gateway: 192.168.10.1
I SIMPLY CANNOT PING 192.168.10.1 from the PC
please help
pings are going from the PC to 192.168.10.2 and 192.168.10.3 but not to 192.168.10.1
the #show standby command displays that the virtual ip is active and well
Please help
Thank you in advance
15 Replies 15
Yes. It is correct that the last two hex digits should be the group number (0A for group 10).
At least we know do know why the ping from the PC is failing. The PC did an arp and the MAC address that it is working with is not the correct MAC. I believe that this incorrect MAC is a result of packet tracer not working correctly.
Rick
Rick
