133
Beginner
HSRP
Can we implement HSRP on two routers that are connected point to point?? Will that work?
Also, if in a HSRP environment i do not configure priority on both the routers, and it takes the default as 100, will HSRP work here? Will traffic pass through??
Navneet
1 REPLY
Frequent Contributor
Re: HSRP
Two HSRP routers may connect point-to-point for HSRP. However if HSRP interfaces are to be used for something useful they must be connected via shared infrastructure.
Only HSRP-like protocol I have seen that works using point-to-point link is NSRP.
No priority is not a problem.
Thanks.
Ask the Expert- Webex Hybrid Services Solutions
