HTTPS web publish in cisco router
errrro
I want to forward HTTPS for this address 77.77.0.2 in cisco router in order when I type https://my public address from outside the router redirect me to 77.77.0.2.
This is my router config:
#show running-config
Building configuration...
Current configuration : 2682 bytes
version 15.3
hostname test
boot-start-marker
boot-end-marker
aqm-register-fnf
enable password ****
no aaa new-model
ip dhcp excluded-address 192.168.1.1
ip dhcp excluded-address 172.77.0.1
ip dhcp excluded-address 172.77.0.2
ip dhcp pool test
network 192.168.1.0 255.255.255.0
dns-server 8.8.8.8
default-router 192.168.1.1
lease 0 1
ip dhcp pool vlan2
network 172.77.0.0 255.255.0.0
default-router 172.77.0.2
dns-server 8.8.8.8
ip cef
no ipv6 cef
interface Loopback0
no ip address
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface FastEthernet0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
switchport access vlan 2
no ip address
interface GigabitEthernet5
no ip address
interface GigabitEthernet6
no ip address
interface GigabitEthernet7
no ip address
interface GigabitEthernet8
ip address 172.0.0.2 255.255.255.252
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Vlan1
ip address 192.168.1.1 255.255.255.0 secondary
ip address (my pblic ip) 255.255.255.252
ip nat inside
interface Vlan2
ip address 192.168.2.1 255.255.255.0 secondary
ip address 172.77.0.1 255.255.0.0
ip nat inside
interface Async3
no ip address
encapsulation slip
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Vlan1 overload
ip nat inside source list 2 interface Vlan1 overload
ip route 0.0.0.0 0.0.0.0 172.0.0.1
snmp-server community te RO
snmp-server enable traps tty
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 2 permit 172.77.0.0 0.0.255.255
access-list 2 permit 192.168.2.0 0.0.0.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
password ****
login
no modem enable
line aux 0
line 3
modem InOut
speed 115200
flowcontrol hardware
line vty 0 4
password ****
login
transport input all
scheduler allocate 20000 1000
end
8 Replies 8
Georg Pauwen
add:
ip nat inside source static tcp 77.77.0.2 443 172.0.0.2 443 extendable
That said, where in your network is 77.77.0.2 ?
Hello
Can you confirm if what you want is to be able to access your internal web server via its public ip address from hosts inside your local network?
res
Paul
Kind Regards
Paul
yes exactly that's what I need.
is the filled in blank (in bold) your public IP ?
nterface Vlan1
ip address 77.77.0.1 255.255.255.252
ip nat inside
What happens in your current setup when you ping 77.77.0.2 from a host in your 192.168.1.0/24 or 192.168.2.0/24 network ?
hi,
77.77.0.2 it's not my public ip, it's the gateway for wifi.
77.77.0.2 ping 192.168.1.0/24 and 192.168.2.0/24.
77.77.0.0/16: wifi
192.168.1.0/24: adminsitration
I am lost. In your original post you say:
So 77.77.0.2 is your WiFi gateway IP address ? And it is not a public IP address ?
Maybe you can post a schematic drawing of your setup, and indicate what you are trying to accomplish...
I want to be able to access to internal server (https://77.77.0.2) via my public ip address from hosts outside my local network.
Hello
Okay due to nat order of operation on domain-based nat  ( ip nat inside/outside) translation is performed differently for nat inside and nat outside this is why I guess it would fail using your current configuration.
Inside Nat = performs a rib look up before translation
Outside Nat = performs translation before rib lookup
NVI nat ( domain-less)  performs two lookups before and after translation and in this case should work in providing you being able to reach your internal web server via is public address from your internal clients
try this:
no ip nat outside
ip nat enable
interface Vlan1
no ip address (my pblic ip) 255.255.255.252
no ip nat inside
ip nat enable
interface Vlan2
no ip nat inside
ip nat enable
no ip nat inside source list 1 interface vlan1 overload
no ip nat inside source list 2 interface vlan2 overload
ip nat source list 1 interface GigabitEthernet8 overload
ip nat source list 2 interface GigabitEthernet8 overload
ip nat source static tcp 77.77.0.2 443 77.77.0.2 443 extendable
res
Paul
Kind Regards
Paul
