HWIC-2SHDSL CRC problems
Hello
Im having problems to ping through interface atm 0/0/0 which is releated to a card HWIC-2SHDSL . The router I have
is a 1941. I dont know what to do.Any clue?
sh ver
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.2(4)M2, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Wed 07-Nov-12 12:45 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
Bruyere uptime is 6 days, 22 hours, 50 minutes
System returned to ROM by reload at 12:50:06 UTC Mon May 13 2013
System image file is "flash0:c1900-universalk9-mz.SPA.152-4.M2.bin"
Last reload type: Normal Reload
sh int atm 0/0/0
ATM0/0/0 is up, line protocol is up
  Hardware is DSLSAR, address is 4403.a715.dda8 (bia 4403.a715.dda8)
  MTU 4470 bytes, sub MTU 4470, BW 4096 Kbit/sec, DLY 110 usec,
  Encapsulation ATM, loopback not set
  Keepalive not supported
  Encapsulation(s): AAL5
  8 maximum active VCs, 256 VCs per VP, 1 current VCCs
  VC Auto Creation Disabled.
  VC idle disconnect time: 300 seconds
  Last input 00:01:40, output never, output hang never
  Last clearing of "show interface" counters 03:14:48
  Queueing strategy: Per VC Queueing
  30 second input rate 0 bits/sec, 0 packets/sec
  30 second output rate 0 bits/sec, 0 packets/sec
     3718 packets input, 197105 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 input errors, 62 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     3953 packets output, 219256 bytes, 0 underruns
     0 unknown protocol drops
Snap of configuration
license udi pid CISCO1941/K9 sn FCZ1709C5EM
username cisco privilege 15 password 0 cisco
redundancy
controller SHDSL 0/0/0
dsl-group 0 pairs  0, 1
  shdsl annex A-B
  shdsl rate 4096
interface ATM0/0/0
no ip address
load-interval 30
no atm ilmi-keepalive
interface ATM0/0/0.1 point-to-point
ip address 172.31.224.166 255.255.255.252
pvc 8/35
  encapsulation aal5snap
ping 172.31.224.165 source 172.31.224.166
Sending 5, 100-byte ICMP Echos to 172.31.224.165, timeout is 2 seconds:
Packet sent with a source address of 172.31.224.166
8 Replies 8
Subeh Sharma
Hi Alejandro,
Please paste the output of the following:
- show controller shdsl 0/0/0
- show atm vc detail
- Also check if the IP you're trying to ping i.e. 172.31.224.165 is indeed the right IP and is pingable (have no ACLs blocking ICMP)
Subeh
paolo bevilacqua
How long, and which gauge size is the loop? It could be impossible to sustain 4 Mbs due to it's physical characteristics.
Hello
Yes the remote interface is pingable. Here you are
Bruyere#show atm vc detail
Description: N/A
ATM0/0/0.1: VCD: 4, VPI: 8, VCI: 35
VBR-NRT, PeakRate: 4096 (9661 cps), Average Rate: 4096 (9661 cps)
Burst Cells: 1
AAL5-LLC/SNAP, etype:0x0, Flags: 0x40, VCmode: 0x0, Encapsize: 12
OAM frequency: 0 second(s)
InARP frequency: 15 minutes(s)
InPkts: 4, OutPkts: 940, InBytes: 272, OutBytes: 50020
InPRoc: 4, OutPRoc: 28, Broadcasts: 0
InFast: 0, OutFast: 0, InAS: 0, OutAS: 0
InPktDrops: 0, OutPktDrops: 0/0/0 (holdq/outputq/total)
CrcErrors: 0, SarTimeOuts: 0, OverSizedSDUs: 0, LengthViolation: 0, CPIErrors: 0
Out CLP=1 Pkts: 0
OAM cells received: 913
OAM cells sent: 913
Status: UP
VC lock count: 1
Description: N/A
ATM0/1/0.835: VCD: 1, VPI: 8, VCI: 35
VBR-NRT, PeakRate: 640 (1510 cps), Average Rate: 640 (1510 cps)
Burst Cells: 1
High Watermark: 0, Low Watermark: 0
InPkts: 51911, OutPkts: 246271, InBytes: 3074755, OutBytes: 13450982
InPRoc: 51911, OutPRoc: 50427, Broadcasts: 0
InFast: 0, OutFast: 195844, InAS: 0, OutAS: 0
Out CLP=1 Pkts: 0
OAM cells received: 195844
OAM cells sent: 195844
Status: UP
VC lock count: 1
Bruyere#show controller shdsl 0/0/0
Controller SHDSL 0/0/0 is UP
  Hardware is HWIC-2SHDSL, rev 1 on slot 0, hwic slot 0
  Capabilities: 2/4 wire, Annex A, B, F & G, CPE termination
  cdb=0x2A0EA648, plugin=0x2A0790CC, ds=0x2A079118 base=0x10000000
  FPGA Version is REL.3.4.0, NIOSII FW:Ver 4.8, status Running
  SDFE-2 HW:Rev 1.3, status UP FW:Ver 1.1-1.7.5__001                 , status Running
  NIOSII Firmware image: System
  SDFE2  Firmware image: System
  Number of pairs 2, number of groups configured 1
  Ignored CLI cmds(0), Event buffer: in use(0), failed(0)
  Group (0) info:
        Type: 4-wire g.shdsl, status: UP
        Interface: ATM0/0/0, hwidb: 0x2A0EA7E4, UTOPIA phy 0
        Configured/active num links: 2/2, bit map: 0x3/0x3
        Line termination: CPE, line mode: 4-wire, Annex-A-B, PMMS disabled
        Line coding: 16-TCPAM, configured/actual rate: 4096/4096 kbps
        SHDSL wire-pair (0) is in DSL UP state
          Termination: CPE, line mode: 4-wire, Annex-A-B
          Line coding: 16-TCPAM, configured/actual rate: 2048/2048 kbps
          CONNECT state: MAIN_DATA_MODE, cond: GHS_TRANSFER, reason: ERR_NONE
          Power back off: 0dB, FE power back off: 0dB
          LoopAttn: 13dB, SnrMargin: 18dB, Status noDefect
          Current 15 minute statistics (Time Elapsed 52 seconds):
                ES: 0, SES: 0, CRC: 0, LOSWS: 0, UAS: 0
          Previous 15 minute statistics:
          Current 24 hr statistics:
          Previous 24 hr statistics:
          ATM-TC Tx: data cells: 26312541, Idle/Unassigned: 1467
          ATM-TC Rx: data cells: 1612, uncorr HEC: 7, corr HEC: 0
          ATM-TC Rx: OCD: 0, LCD start: 0, LCD end: 0
        SHDSL wire-pair (1) is in DSL UP state
          CONNECT state: MAIN_DATA_MODE, cond: GHS_STARTUP, reason: ERR_NONE
          LoopAttn: 13dB, SnrMargin: 19dB, Status noDefect
          Current 15 minute statistics (Time Elapsed 23 seconds):
          ATM-TC Tx: data cells: 0, Idle/Unassigned: 0
          ATM-TC Rx: data cells: 0, uncorr HEC: 0, corr HEC: 0
  Group (1) is Not configured.
Alejandro,
Please configure the following under atm interface:
pvc 8/35
   protocol ip 172.31.224.165 broadcast
Also, make sure there is no PPP involved. If it is then you need to bind this atm interface to a dialer interface or virtual-template and configure the IP there.
Subeh
Subeh Sharma wrote:
Alejandro,
pvc 8/35
That will have no effect. When using point-to-point subinterface, there is no need to configure "protocol etc" under PVC.
hi
do you think there may exist a problem with the cabling between the card RJ-11 port and the provider wall box?
Or as the controller is up that is not a problem.
Alejandro,
Since the controller and ATM is up, we can remove any physical level problem. Please check with your provider if the connection you got from them requires PPP.
Subeh
No. Check things with you ISP.
