Highlighted
Beginner
HWIC-3G-GSM
Will you please help me to solve the following problem?
Two HWIC-3G-GSM modems (Sierra MC8775) have been installed in Cisco Router 2851 (iOS 15.1(4)M7)
In each modem has SIM cards of different operators
Modems` versions   - firmeware 2.08.19.
Modem connection is establishing but is breaking off because of unaccountable reasons
The lost the connection can occur in 5 minutes after switching on, as well as in 2 or 3 hours.
The following information is displayed In debug :
Dec 8 18:03:53: %LINK-3-UPDOWN: Interface Cellular0/0/0, changed state to down
Dec 8 18:04:03.029: Ce0/0/0 DDR: re-enable timeout
Dec 8 18:04:03.877: Ce0/0/0 DDR: place call
Dec 8 18:04:03.877: Ce0/0/0 DDR: Dialing cause ip (s=10.173.119.105, d=8.8.8.8)
Dec 8 18:04:03.877: Ce0/0/0 DDR: Attempting to dial mts
Dec 8 18:04:03.877: CHAT0/0/0: Attempting async line dialer script
Dec 8 18:04:03.877: CHAT0/0/0: Dialing using Modem script: mts & System script: none
Dec 8 18:04:03.881: CHAT0/0/0: process started
Dec 8 18:04:03.881: CHAT0/0/0: Asserting DTR
Dec 8 18:04:03.881: CHAT0/0/0: Chat script mts started
Dec 8 18:05:03.876: CHAT0/0/0: Chat script mts finished, status = Connection timed out; remote host not responding
Dec 8 18:05:03.876: Ce0/0/0 DDR: disconnecting call
It`s necessary to reload cisco due to reinstall the connection again
Config:
chat-script MTS "" "ATDT*99***1#" TIMEOUT 60 "CONNECT"
interface Cellular0/0/0
ip unnumbered Dialer2
ip nat outside
ip virtual-reassembly in
encapsulation ppp
load-interval 60
dialer in-band
dialer pool-member 2
dialer-group 1
async mode interactive
ppp chap hostname mts
ppp chap password 7 11040D16
ppp ipcp dns request
interface Dialer2
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 2
dialer idle-timeout 0 either
dialer string MTS
dialer persistent delay initial 2
dialer-group 1
line 0/0/0
script dialer MTS
login ctrlc-disable
modem InOut
no exec
rxspeed 7200000
txspeed 384000
