hwic-3g-hspa 1921
davidsudjiman
Hi all,
I've been using hwic-3g-hspa with 1841 before but now I'm using 1921 and I'm always getting timed-out
ROUTER#sh ver
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.1(4)M, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 24-Mar-11 13:55 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M9, RELEASE SOFTWARE (fc1)
ROUTER uptime is 33 minutes
System returned to ROM by reload at 17:20:13 aest Thu Jun 16 2011
System image file is "usbflash0:c1900-universalk9-mz.SPA.151-4.M.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO1921/K9 (revision 1.0) with 487424K/36864K bytes of memory.
Processor board ID <SERIAL>
6 Gigabit Ethernet interfaces
3 terminal lines
1 Virtual Private Network (VPN) Module
2 Cellular interfaces
DRAM configuration is 64 bits wide with parity disabled.
255K bytes of non-volatile configuration memory.
250864K bytes of USB Flash usbflash0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO1921/K9          <SERIAL>
Technology Package License Information for Module:'c1900'
Technology    Technology-package          Technology-package
              Current       Type          Next reboot
ipbase        ipbasek9      Permanent     ipbasek9
security      securityk9    Permanent     securityk9
data          None          None          None
ROUTER#sh run int cel 0/0/0
Building configuration...
Current configuration : 251 bytes
interface Cellular0/0/0
no ip address
ip virtual-reassembly in
encapsulation ppp
load-interval 60
dialer in-band
dialer pool-member 1
async mode interactive
end
ROUTER#sh run int dialer 1
Current configuration : 430 bytes
interface Dialer1
ip address negotiated
encapsulation ppp
dialer pool 1
dialer idle-timeout 0
dialer string <DIALER_SCRIPT>
dialer persistent
dialer-group 1
ppp authentication pap callin
ppp chap refuse
ppp pap sent-username <USERNAME> password 7 <PASSWORD>
ppp ipcp dns request
no cdp enable
end
ROUTER#sh run | s line 0/0/0
line 0/0/0
exec-timeout 0 0
script dialer <DIALER_SCRIPT>
modem InOut
no exec
transport input all
ROUTER#sh run | i chat
chat-script <DIALER_SCRIPT> "" "ATDT*98*4#" TIMEOUT 30 CONNECT
ROUTER#
ROUTER#sh cel 0/0/0 profile
Profile password Encryption level: 7
Profile 1 = INACTIVE*
PDP Type = IPv4
Access Point Name (APN) =
Authentication = None
Username: , Password: 03
Profile 4 = INACTIVE
PDP Type = IPv4
Access Point Name (APN) = <APN>
Authentication = PAP
Username: <USERNAME>, Password: <PASSWORD>
* - Default profile
*Jun 16 17:52:40.323: Ce0/0/0 DDR: re-enable timeout
*Jun 16 17:52:41.323: Ce0/0/0 DDR: rotor dialout [best] least recent failure is also most recent failure
*Jun 16 17:52:41.323: Ce0/0/0 DDR: rotor dialout [best] also has most recent failure
*Jun 16 17:52:41.323: Di1 DDR: Nailing up the Dialer profile [attempt 18]
*Jun 16 17:52:41.323: Di1 DDR: Dialer dialing - persistent dialer profile
*Jun 16 17:52:41.323: Ce0/0/0 DDR: Dialing cause Persist
*Jun 16 17:52:41.323: Ce0/0/0 DDR: Attempting to dial <DIALER_SCRIPT>
*Jun 16 17:52:41.323: CHAT0/0/0: Attempting async line dialer script
*Jun 16 17:52:41.323: CHAT0/0/0: Dialing using Modem script: <DIALER_SCRIPT> & System script: none
*Jun 16 17:52:41.323: CHAT0/0/0: process started
*Jun 16 17:52:41.323: CHAT0/0/0: Asserting DTR
*Jun 16 17:52:41.323: CHAT0/0/0: Chat script <DIALER_SCRIPT> started
*Jun 16 17:52:41.323: CHAT0/0/0: Sending string: ATDT*98*4#
*Jun 16 17:52:41.323: CHAT0/0/0: Expecting string:
*Jun 16 17:53:11.323: CHAT0/0/0: Timeout expecting: CONNECT
*Jun 16 17:53:11.323: CHAT0/0/0: Chat script <DIALER_SCRIPT> finished, status = Connection timed out; remote host not responding
*Jun 16 17:53:11.323: Ce0/0/0 DDR: disconnecting call
*Jun 16 17:53:26.323: Ce0/0/0 DDR: re-enable timeout
*Jun 16 17:53:27.323: Ce0/0/0 DDR: rotor dialout [best] least recent failure is also most recent failure
*Jun 16 17:53:27.323: Ce0/0/0 DDR: rotor dialout [best] also has most recent failure
*Jun 16 17:53:27.323: Di1 DDR: Nailing up the Dialer profile [attempt 19]
*Jun 16 17:53:27.323: Di1 DDR: Dialer dialing - persistent dialer profile
*Jun 16 17:53:27.323: Ce0/0/0 DDR: Dialing cause Persist
*Jun 16 17:53:27.323: Ce0/0/0 DDR: Attempting to dial <DIALER_SCRIPT>
*Jun 16 17:53:27.323: CHAT0/0/0: Attempting async line dialer script
*Jun 16 17:53:27.323: CHAT0/0/0: Dialing using Modem script: <DIALER_SCRIPT> & System script: none
*Jun 16 17:53:27.323: CHAT0/0/0: process started
*Jun 16 17:53:27.323: CHAT0/0/0: Asserting DTR
*Jun 16 17:53:27.323: CHAT0/0/0: Chat script <DIALER_SCRIPT> started
*Jun 16 17:53:27.323: CHAT0/0/0: Sending string: ATDT*98*4#
*Jun 16 17:53:27.323: CHAT0/0/0: Expecting string:
*Jun 16 17:53:57.323: CHAT0/0/0: Timeout expecting: CONNECT
*Jun 16 17:53:57.323: CHAT0/0/0: Chat script <DIALER_SCRIPT> finished, status = Connection timed out; remote host not responding
*Jun 16 17:53:57.323: Ce0/0/0 DDR: disconnecting call
Can somebody assist?
davidsudjiman
Sorry guys, false alarm. This is Provider issue. It's fixed now.
