690
Layne Ivy
Beginner
Hwic-4t1/e1
I am having an issues programming my 2911 router with a hwic-4t1/e1 card for three bonded t1's with ppp.
Both the router and the Hwic are fresh out of the box. I have a very simple setup. I have 3 bonded leased t1 lines through AT&T to Time Warner Telecom's router using xxx.xxx.xxx.x45 on their end and xxx.xxx.xxx.x46 for my end.
I installed the Hwic and then did these commands to enable and set up to work with theirs like i was told:
     (Basic....)
>enable
#config t
g)#hostname main
g)#no ip domain-lookup
      (SSH...)
g)#username <username> password <pw>
g)#ip domain-name main.com
g)#crypto key generate rsa
g)#512
g)#ip ssh ver 2
g)#line vty 0 5
line)#login local
line)#transport input ssh
line)#exit
     (install hwic)
g)#card type t1
g)#network-clock-participate wic 0
     (config hwic controllers)
g)#controller T1 0/0/0
er)#faming esf
er)#linecode b8zs
er)#Fdl att
er)#clock source line
er)#loopback remote esf line
er)#cablelength short 110
er)#crc-threshold 320
er)#no yellow detection
er)#exit           (repeated for 0/0/1 and 0/0/2)
     (internal interfaces)
g)#int g0/0
f)#ip address 10.0.0.254 255.25.255.0
f)#no shut
     (Destination of last resort)
g)#ip route 0.0.0.0 0.0.0.0 xxx.xxx.xxx.x45
     (multilink ppp)
g)#int multilink 1
f)#ip add xxx.xxx.xxx.x46 255.255.255.252    (I get a error here saying it overlaps with a static route in the route table.)(so it wont accept it)
f)#no cdp enable
f)#ppp multilink
f)#ppp multilink group 1
f)#exit
     (Adding interfaces to multilink group 1)
g)#int T1 0/0/0 (I get an error here saying invalid input at 1st 0 of 0/0/0) (So i tried "int T1 ?" and all i get is <cr> so I tried "interface ?" to see all possible interfaces and all i get are :
                                        Async, Auto-template, BVI, CDMA-Ix, CTunnel, Dialer, Embedded-service-engine, GigE, Group async, LongReachEthernet, loopback, MFR, Multilink, Null, Port-channel, Pseudowire, Tunnel, VIF, Virtual-PPP, Virtual-Template, Virtual-TokenrRing, range, vmi
     -At this point I dont know what to do?? I had planned on:
g)#int T1 0/0/0
f)#no ip address
f)#encap PPP
f)#no fair-queue
f)#ppp multilink
f)#exit
(repeated for 0/0/1 and 0/0/2 but obviously if i can't get into the interface config i can't set these commands)
     -So i went on to nat....
g)#access-list 5 permit 10.0.0.0 0.0.0.255
g)#ip nat inside source list 5 interface T1 0/0/0 overload (obviously this didn't work, so I tried "ip nat inside source list 5 interface t1 overload")
     -It took but it I think it has something to do with ??tunnel?? (I dont really understand tunnels)
g)#int g0/0
f)#ip nat inside
f)#exit
g)#int T1 0/0/0 (again didn't work so I used "int T1" and it took)
f)#ip nat outside
f)# exit
1 ACCEPTED SOLUTION
In each controller interface add "channel-group 0 timeslots 1-24"
This will create serial interfaces. Configure each as
No ip addr
Encap PPP
PPP multilink
PPP multilink group 1
On int multilink 1 add your IP address, PPP multilink and ppp multilink group 1
5 REPLIES 5
Jeff Van Houten
Contributor
On each controller interface you need a channel group. That command creates the serial interfaces you need to join into the multi link group.
No ip addr
Encap PPP
PPP multilink
Layne Ivy
Beginner
Thanks Jeff that got my serial interface to show up!
But I am still having the problem with my IP address on my multilink interface. Whenever I enter the ip address command i get an error saying that the ip address conflicts with the static routes. I checked the routing table and the only thing that shows is on g0/0 my connected 10.0.0.0/24? I don't understand what the conflict is. Do I need to look elsewhere for an issue?
Jeff Van Houten
Contributor
It may just be a typo but the subnet mask on g0/0 is off.
Also if you have any addresses on any interface other than g0/0 or multilink 1, remove them. And your in nat outside needs to be in the multilink interface as well as the nat statement.
