I am not able to ping to other network which it connect etherswitch module
chandru.j
   From Router 3925 which it has SM-ES3G-16-P etherswitch module from that module we have connect three more router in which is in different locations. I configured switch module and other end router i am able to ping each other. But i am able to ping from 3925 router if login into switch module i am able to ping. etherswitch has c3560-e-unviresal-mz-22.2(52) IOS. Whe i check eith some document that i need to configure vlan 1 ip add as same subnet of gigabit interface of switch module .Even though its not pinging. i need a help in this.
thanks in advance.
Have you tried using the no switchport command and then applying an IP address to the etherswitch port that connects to another router?
This would make it a routed port, which may be what you need.
Regards, Ash.
hi,
   Yes i given after that switched will be routed port then i am able give ip address to that port.
Hello Chandru.j
Could you help me with the steps to configure and  SM-ES3G-16-P Module ? I am really new and I have to configure that card to conect  3 routers.
