Join Customer Connection to register!
2259
Highlighted
I need change redandunt mode SSO to redandunt mode none ,and upgrade IOS XE ,I correct ?
1. I upload new IOS-XE  and check boot system bootflash:/NewIOS   (I will must upgrade rommon ?)
2. I change configuration "redandunt mode sso to redandunt mode none" after I will copy run start  (I correct ? or any concern such as show platfrom, show version, dir ect, )
3. I can be reload for ASR take newios redandunt mode none.
I correct all ?
Thank you for respones.
Sittichai T.
2 ACCEPTED SOLUTIONS
Highlighted
Hi Sittichai,
Could you explain in more details on why do you want to change redunancy mode to none? Do you use IOS process redundancy on it?
Also, please post "show platform" command output here.
Generally, if you do not care about service impact due to the router reload, on any ASR router you can change the boot string to point to new image, save configuration and reload the router.
For less service impact, you should use ISSU procedure, which you can see in the following guide:
http://www.cisco.com/en/US/docs/routers/asr1000/configuration/guide/chassis/issu.html#wp1218296
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
Highlighted
If you want to change to single process, config the following:
     Router# configure terminal
     Router(config)# redundancy
     Router(config-red)# mode none
     Router(config-red)# end
     Router#
There is no need to run "issu runversion". Since you are doing service impacting upgrade with router reload, you just need to change the boot string and reload:
     Router#show run | i boot     //find the current boot string, e.g. "boot system bootflash:/IOS-XE/packages.conf"
     //remove the old boot string now, using the output you got above, e.g.:
     Router(config)# no boot system bootflash:/IOS-XE/packages.conf
     //add new boot string, specify correct path
     Router(config)# boot system bootflash:/IOS-XE/asr1000rp1-advipservicesk9.03.04.03.S.151-3.S3.bin
     //save config
     wr
     //reload to load new image
     reload
Note that this is service impacting upgrade!
You can also use ISSU packages upgrade procedure but that requires 2 IOS processes to be configured:
http://www.cisco.com/en/US/docs/routers/asr1000/configuration/guide/chassis/issu.html#wp1162196
Kind Regards,
Ivan Shirshin
Kind Regards,
Ivan
4 REPLIES 4
Highlighted
Hi Sittichai,
Kind Regards,
Ivan Shirshin
Kind Regards,
Ivan
Highlighted
current I used ASR1002 1 unit version Version 12.2(33)XNF2   IOS-XE :asr1000rp1-advipservicesk9.02.06.01.122-33.XNF1.bin
and redundancy mode sso
but, I need to single process , I can be upgrade  asr1000rp1-advipservicesk9.03.04.03.S.151-3.S3.bin in ASR1002 ?
and I refer by command issu runningversion and result
ASR#issu runversion
--- Starting local lock acquisition on R0 ---
Finished local lock acquisition on R0
FAILED: Operation runversion cannot be performed: no install in progress
I just need redundancy mode none  and upgrade IOS-XE from 12.33 to 15.1-3
PS. now :bootflash:/IOS-XE/packages.conf   ,
I will change bootflash:/IOS-XE/asr1000rp1-advipservicesk9.03.04.03.S.151-3.S3.bin and change redundancy mode none and reload for take router  ---- but I don't sure after tranfrom 12.33 to 15.1
please make sure to me.
Thank you,
Sittichai Taykum
Highlighted
     Router#
     //save config
     wr
     reload
Kind Regards,
Ivan Shirshin
Kind Regards,
Ivan
Highlighted
Thank you for information Ivan,
I was try follow you,
after reboot ASR can used single processer  but, when I show redundancy  configure still mode sso
I used in config t and redundancy and default-exit  and enter  and save  non reboot  after then show config again config in redundacy mode none
thank you very much ...!!
