Join Customer Connection to register!
189
Octavio Alfageme
Beginner
iBGP session's MSS misalignment
Dear all,
I have two Cisco 7609S (R1 runs 15.2(4)S1 and R2 runs 15.3(3)S1) running iBGP between them, apart from OSPF as IGP, and connected by a STM4 SONET link. After the IOS upgrade of R2 from 15.2(4)S1 to 15.3(3)S1, I saw that iBGP session's MSSs  were misaligned even though PMTUD discovery is enabled by default.
I get the following outputs:
R2#sh ip bgp neighbors [R1's ip address]
  BGP state = Established, up for 1w0d
  Connections established 1; dropped 0
  Last reset never
  Transport(tcp) path-mtu-discovery is enabled
  Graceful-Restart is enabled, restart-time 120 seconds, stalepath-time 360 seconds
SRTT: 1000 ms, RTTO: 1003 ms, RTV: 3 ms, KRTT: 0 ms
minRTT: 120 ms, maxRTT: 1000 ms, ACK hold: 200 ms
Status Flags: active open
Option Flags: nagle, path mtu capable
IP Precedence value : 6
Datagrams (max data segment is 4406 bytes):
R1#sh ip bgp neighbors [R2's ip address]
Connections established 2; dropped 1
  Last reset 1w0d, due to Active open failed
SRTT: 320 ms, RTTO: 323 ms, RTV: 3 ms, KRTT: 0 ms
minRTT: 120 ms, maxRTT: 976 ms, ACK hold: 200 ms
Status Flags: passive open, gen tcbs
Option Flags: nagle
Datagrams (max data segment is 556 bytes):
As you can see:
  • both routers have PMTUD enabled to find the biggest MSS previously to BGP negotiation
  • however, R2 shows an MSS of 4406 bytes and R1 only 556 bytes
  • additionaly, R1 doesn't show "path mtu capable" among the "Option Flags"
STM4 interfaces IP MTU is 4470 bytes in both sides of the link and there is no bottleneck in the link that blocks of fragment packets of that size.
From my point of view there has to be with the path mtu discovery, but I'm not sure.
I would really appreciate any comment to help me to understand why this misalignment takes place.
Thanks in advance
Octavio
0 REPLIES 0
