iBGP
tushar47
Dear sir,
Please tell me, what is the significance of iBGP.
Ashu
Hello Ashu,
iBGP, as opposed to eBGP, is used for internal peering, that is peering within the same AS. eBGP is used to interconnect different ASs...
Check this link and scroll down to the drawing, it visualizes the difference:
An Introduction to the BGP Protocol
http://www.skullbox.net/bgp.php
HTH,
GP
r.waldron
IBGP....all peers or routers are coverd in the same AS number and they mesh connection...but they are many other features,,between IBGP ( Internal BGP ) and EBGP ( External BGP )...hope that helps
Roddy
michaelgstout
ibgp is useful if a network has redundant isp connections. If R1 and R2 are in your AS and you want to connect each router to a different AS, you would use ibgp between R1 and R2 to provide your network with connectivity two or more seperate autonomous systems.
vpalania
iBGP advertises networks to other iBGP neighbours(routers within same AS).Whereas eBGP advertises networks to other eBGP neighbours(routers in different AS).There is no separate configuration commands.They are identified by AS number specified in the router bgp .The Neighbourship between iBGP routers should be full mesh,since routes learned via an iBGP router are never propagated too another iBGP routers.
Hope this clears you.If so rate this post.
Gilli
