ICMP cache is empty
dattsNet07
Community Member
I am trying to configure a C9300. I have the vlan100 configure with a default gateway which I can ping. However on a PC I connect to the switch, it shows connection limited. When i do ''show ip redirects'' is show the following message.''ICMP CACHE IS EMPTY'' How can i solved that in other to have land activated?
Thank you for your help
Hello Guys,
Thank you to all of you who had offered me help to solve my issue. I have found a solution. After some change in my routing table and modification in my firewall, everything came up smoothly.
Once again thank you, see you in the next issue.
17 Replies 17
Georg Pauwen
it is unclear what you are trying to ping. What is the IP address of the PC, and what IP address are you trying to ping ? Is the C9300 configured as a layer 2 or layer 3 switch ?
I have try to ping the default gateway ip. my switch is a L3
I had a wrong default gateway set, i have added a new one but did not delete the other on. would this be the problem.
In other hand, shoud i assign a ip to the default vlan1 to ?
I am lost.
Please help
I would do a:
9300#factory-reset all
and start from scratch. With the correct default gateway configured then, see if the problem persists...
the SVI for Vlan 100 is configured on that same switch, and you are trying to ping the IP address of the Vlan 100 SVI from a PC in that same Vlan ?
Post the configuration of your switch and indicate which port the PC is connected to...
the L3 switch is connected to a router on port 23 that i assigned and the PC is connected to a random port.
But my idea is to connect a other switch and have the PC connected to it.
To resume have: the router=>connect to the switch on port 23=> the distribution switch2 on any port=> the pc
what happen is that when i connect the PC to the switch i get network limited.
I though that creating a layer 3 swith. But when i connect the PC to the switch2 as in the resume(shown above) i have no connection at all.
as per the description below :
can you post the switch config and router config to look, is PC Set to DHCP ? what is PC IP address ?
BB
the PC is set to DHCP.
i will post the switch config in few minutes
You must enable routing
Example: Router(config)#ip routing
Hello
Has the l2 vlan been created for that SVI and assigned it to an access port
conf t
vlan 100
exit
Int xx
swtichport mode access
switchport access vlan 100
Kind Regards
Paul
Sorry for the delay in responding.
I have assigned  a port to vlan1.
To the vlan have assigned the gateway. witch would be applied to vlan 100 as well, where all the other port are assigned for traffic.
What else should i do or correct in other to have my L3 switch communication to my router through the HSPR address.
Thank you
For me i still do not see much information here, can you post switch configuration?
what is VLAN I 100 IP address, what is VLAN 1 IP address here?
what is the Router IP? what is the PC IP you got and you are trying to Ping? - what device offering you DHCP IP reservation? Switch or router?
BB
Sorry guy for the delay, I was out for a while. Your help is really appreciated.
I have passed below the config, please add your comments. I have added a drawing of what I am trying to archive.
Thank you
Version 2.0
 name DATA
class-map match-any system-cpp-police-topology-control
  description Topology control
  description Protocol snooping
class-map match-any system-cpp-police-dhcp-snooping
  description DHCP snooping
class-map match-any system-cpp-police-system-critical
  description System Critical and Gold Pkt
policy-map system-cpp-policy
interface GigabitEthernet0/0
 vrf forwarding Mgmt-vrf
 no ip address
 shutdown
 negotiation auto
interface GigabitEthernet1/0/1
 switchport mode access
 spanning-tree portfast
interface GigabitEthernet1/0/23
 switchport mode trunk
interface GigabitEthernet1/0/24
 switchport trunk native vlan 100
 switchport trunk allowed vlan 100
 spanning-tree guard none
interface GigabitEthernet1/1/1
interface Vlan1
 no ip address
interface Vlan100
 ip address 1.2.2.3_3 255.255.255.0
 ip helper-address 1.1.2.9
ip default-gateway 1.2.2.3
ip forward-protocol nd
 ip ssh version 2
line con 0
 stopbits 1
line vty 5 15
ntp server 1.1.1.2
end
