ICMP on external interface
sbrown6079
Not sure how to accomplish this, and I've been beating on it for a few days. My knowledge of IOS is increasing, but still limited in scope so I'm hopeful someone can help me out
I've got a Cisco 1811 router with FastEthernet0 plugged into a cable modem with 5 static IP's. I want to disable the ability for those IP's to be pinged externally except for certain addresses that I specify (I have some offsite servers that I use to monitor the ISP link for example). I also want the ability to be able to ping external addresses from the router as well as any of my inside subnets.
Here are the subnets I use:
10.0.0.0/24
10.0.10.0/24
10.0.20.0/24
10.0.30.0/24
I've tried varying ACL's and applied to Fa0, none of which work
Here is what is built currently:
sunvalleyedgrtr01#sh access-lists 102
Extended IP access list 102
    10 permit icmp 10.0.0.0 0.0.0.255 any echo
    20 permit icmp 10.0.0.0 0.0.0.255 any echo-reply
    30 permit icmp 10.0.10.0 0.0.0.255 any echo
    40 permit icmp 10.0.10.0 0.0.0.255 any echo-reply
    50 permit icmp 10.0.20.0 0.0.0.255 any echo
    60 permit icmp 10.0.20.0 0.0.0.255 any echo-reply
    70 permit icmp 10.0.30.0 0.0.0.255 any echo
    80 permit icmp 10.0.30.0 0.0.0.255 any echo-reply
    90 deny icmp any any echo (3147 matches)
    100 deny icmp any any echo-reply (5 matches)
    110 permit ip any any (428006 matches)
And the relevant config for Fa0:
Outgoing access list is 102
Inbound  access list is 102
I think I'm on the right path with how to accomplish what I want to do, but it's not working as anticipated and I'm struggling just a bit trying to get there. The example above is disabling the ability to ping anything, externally or from my subnets.
John Blakley
If you're cable modem is connected to fa0/0, then that's going to be your outside interface. Where are the 10.x.x.x subnets at in your router? Are they on fa0/0 or fa0/1? Does your router do the natting or cable modem/router? Do you have any other equipment in between you like a firewall, etc? The acl looks fine, I figure it's placed on the incorrect interface. Can you post the interface configs?
HTH,
John
HTH, John *** Please rate all useful posts ***
Yes, cable modem is connected to FastEthernet0. The 10.x.x.x subnets are built as subinterfaces/vlans under FastEthernet1, Fa1.1, Fa1.10, Fa1.20, Fa1.30. Router does the NAT'ing.
Here's the interface config for Fa0:
sunvalleyedgrtr01#sh ip int fa0
FastEthernet0 is up, line protocol is up
  Internet address is (omitted)
  Broadcast address is 255.255.255.255
  Address determined by non-volatile memory
  MTU is 1500 bytes
  Helper address is not set
  Directed broadcast forwarding is disabled
  Secondary address (omitted)
  Proxy ARP is disabled
  Local Proxy ARP is disabled
  Security level is default
  Split horizon is enabled
  ICMP redirects are never sent
  ICMP unreachables are never sent
  ICMP mask replies are never sent
  IP fast switching is enabled
  IP fast switching on the same interface is disabled
  IP Flow switching is disabled
  IP CEF switching is enabled
  IP CEF switching turbo vector
  IP multicast fast switching is enabled
  IP multicast distributed fast switching is disabled
  IP route-cache flags are Fast, CEF
  Router Discovery is disabled
  IP output packet accounting is disabled
  IP access violation accounting is disabled
  TCP/IP header compression is disabled
  RTP/IP header compression is disabled
  Policy routing is disabled
  Network address translation is enabled, interface in domain outside
  BGP Policy Mapping is disabled
  Input features: Stateful Inspection, Virtual Fragment Reassembly, Access List, Virtual Fragment Reassembly After IPSec Decryption, uRPF, NAT Outside, MCI Check
  Output features: Post-routing NAT Outside, Stateful Inspection, Access List, NAT ALG proxy
  WCCP Redirect outbound is disabled
  WCCP Redirect inbound is disabled
  WCCP Redirect exclude is disabled
  IP verify source reachable-via RX, allow default, ACL 100
   0 verification drops
   0 suppressed verification drops
   0 verification drop-rate
All of the internal interfaces are built the same, I'll post Fa1.10 as an example:
FastEthernet1.10 is up, line protocol is up
  Internet address is 10.0.10.1/24
  MTU is 1500 bytes
  Outgoing access list is not set
  Inbound  access list is not set
  IP fast switching on the same interface is enabled
  Network address translation is enabled, interface in domain inside
  Input features: Stateful Inspection, Virtual Fragment Reassembly, Virtual Fragment Reassembly After IPSec Decryption, MCI Check
  Output features: NAT Inside, Stateful Inspection, NAT ALG proxy
Stephen
Ah...okay. Split your list up for the subinterfaces and you should be okay.
Extended IP access list 103
    50 permit icmp 10.0.30.0 0.0.0.255 any echo
    60 permit icmp 10.0.30.0 0.0.0.255 any echo-reply
Etc....
int fa1.20
ip access-group 102 in
int fa1.30
ip access-group 103 in
You don't need them in the outbound direction...
HTH,
John
Please rate if helpful...
