icmperr in nat
anthonyfear
Hi all
getting intermittent connection problems with a server behind 837 router configured with nat overload. IOS 12.3(8)-YI2.
When connection problem occurs a show ip nat translations shows an icmperr to the server's ip adress. What does this mean?
Any ideas?
fmeetz
Level 4
Level 4
Solution: IOS upgrade 12.4(5) or later
Danilo Dy
There is an IOS bug regarding icmperr in the show ip nat translation output.
The fix is to upgrade your IOS image.
Symptoms:
A router may stop translating packets using NAT, when a NAT entry with
protocol "icmperr" is observed in the "show ip nat translation" output.
Conditions:
These sysmptoms are observed in a Cisco router when the router is
configured with only dynamic NAT translations with a single address in
the NAT pool, or when configured using "interface overload".
Workaround:
To clear all the NAT translations using "clear ip nat trans *" command.
This is a problem in recent PI6 images. It did not occur in PI6 images
built prior to January 1st, 2005.
To allow additional translations to be created while the router has
created one with the ICMPERR, what you would need to do is to create an
IP NAT POOL containing more than 1 public IP address and perform NAT
overload over it. This way, when one of the IP addresses is taken over
by this erroneous translation, the other IP addresses will still be
able to be used as the Inside Global address. You will also have to
reduce the ICMP nat timeout so the router punts out the icmperr
translation sooner making the used IP address available again.
