392
Highlighted
Beginner
IKE Needs to Negotiate IPSec SAs Problem
I have a network configuration with two routers and the internet in the middle with an ipsec VPN as backup. When I run simulation in packet tracer the packet stops at the firewall and this error comes up, "the interesting traffic can not be encrypted, IKE needs to negotiate IPSec SAs." Below are my configurations for one of the routers since they both get the same message.
hostname FWB
no ip cef
no ipv6 cef
crypto isakmp policy 10
encr aes
authentication pre-share
group 2
crypto isakmp key vpnpa55 address 100.1.1.2
crypto ipsec transform-set VPN-SET esp-aes esp-sha-hmac
crypto map VPN-MAP 10 ipsec-isakmp
set peer 100.1.1.2
set transform-set VPN-SET
match address VPN-TRAFFIC
spanning-tree mode pvst
interface FastEthernet0/0
no ip address
duplex auto
speed auto
shutdown
interface FastEthernet0/1
no ip address
duplex auto
speed auto
shutdown
interface Serial0/0/0
ip address 100.2.2.2 255.255.255.252
ip access-group 120 in
ip nat outside
crypto map VPN-MAP
interface Serial0/0/1
bandwidth 64
ip address 192.168.20.1 255.255.255.252
ip nat inside
clock rate 64000
interface Vlan1
no ip address
shutdown
ip nat inside source list 100 interface Serial0/0/1 overload
ip classless
ip route 192.168.2.0 255.255.255.0 192.168.20.2
ip route 0.0.0.0 0.0.0.0 Serial0/0/0
ip flow-export version 9
ip access-list extended VPN-TRAFFIC
permit ip 192.168.2.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 120 permit ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 120 permit ip 192.168.1.0 0.0.0.255 any
access-list 120 permit ip 200.3.4.0 0.0.0.255 any
access-list 100 deny ip 192.168.2.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 100 permit ip 192.168.2.0 0.0.0.255 any
line con 0
line aux 0
line vty 0 4
login
end
Joe
Everyone's tags (1)
1 ACCEPTED SOLUTION
Highlighted
VIP Mentor
Re: IKE Needs to Negotiate IPSec SAs Problem
there were multiple problems with your configurations:
1. incorrect static routes on all 5 routers
2. incorrect NAT exemption statement for VPN traffic in NAT access lists (100)
3. NAT inside and outside interfaces switched
4. access-list 120 blocking all Internet inbound and outbound traffic
Review the attached file and see if you can make sense of it...
12 REPLIES 12
Highlighted
Beginner
Here is my topology.
Highlighted
VIP Mentor
the problem is likely the IP addressing of your inside interface. You have configured:
bandwidth 64
--> ip address 192.168.20.1 255.255.255.252
ip nat inside
clock rate 64000
while all your access lists specify 192.168.2.0/24. There also is a route that you don't need. It is probably faster to change the IP address of the inside interface, rather than to change all the access lists. So make the changes marked in bold:
bandwidth 64
--> ip address 192.168.2.1 255.255.255.252
ip nat inside
clock rate 64000
ip classless
--> no ip route 192.168.2.0 255.255.255.0 192.168.20.2
Highlighted
Beginner
The 192.168.20.1 Is the IP that connects to router B. Router B's other IP is 192.168.20.2. I am pretty sure it does not have to be changed?
Highlighted
Hall of Fame Master
Hello @Lesus ,
looking at your network topology diagram the IP subnet 192.168.2.0/24 is the LAN behind RTRB downstream FWB.
And your configuration of FWB looks like correct.
You need to verify the configuration of the IPSec peer regarding ISAKMP and regarding the ACL of interesting traffic.
The two ACLs must be a mirror of each other with a swap of the subnets with the following logic:
permit ip <local-LAN> <local-LAN-wildcard-mask> <remote-LAN> <remote-LAN-wildcard-mask>
Hope to help
Giuseppe
Highlighted
Beginner
I do have an ACL specifying both subnets that is mirrored like you said called VPN-TRAFFIC. Both the 192.168.1.0 and 192.168.2.0.
Highlighted
VIP Mentor
I am lost to be honest:
bandwidth 64
ip nat inside
clock rate 64000
How is that interface (ip nat inside) connected to the other router ? It is the inside. What traffic are you trying to encrypt ? Actually, post your zipped Packet Tracer project (.pkt) file here as an attachment...
Highlighted
Beginner
Sorry, very hard to explain everything! Attached is my .pkt file.
Highlighted
VIP Mentor
where is the attachment ?
Highlighted
Beginner
Highlighted
VIP Mentor
Highlighted
Beginner
Thank you, I now understand what I did wrong! Thanks for your help!
Highlighted
Beginner
192.168.2.0 is Host B's subnet just to add.
