IKEv2-ERROR
PhoenixNetwork
I am working with the Cisco Catalyst IR1101 router, which run the ir1101-universalk9.17.12.04 firmware. I have been trying to configure a site to site tunnel.
If I start the router up with the default factory configuration and add these lines 1 by 1:
crypto ikev2 keyring MYKEYRING
 peer SITE-A
 address 10.10.10.10
 pre-shared-key ABCABCABC
crypto ikev2 proposal SITE-A-PROP
 encryption aes-cbc-256
The IKEv2 debug log will show me this error message:
IKEv2-ERROR:
: unable to convert to cipher
If I add another line:
 integrity sha256
Then I get this IKEv2 error message:
IKEv2-ERROR:
: unable to convert to mac
When choosing encryption, I get these 7 options:
3des
aes-cbc-128
aes-cbc-192
aes-cbc-256
aes-gcm-128
aes-gcm-256
des DES
I get the IKEv2 error on the encryption part, when I choose any of the aes-cbc encryption.I will need to use aes-cbc-256.
It hardware router limitations' you can not select aes-cbc' you need to select des or 3des.
MHM
