im unable to enable t1/e1 card
m.ateeque
hello all,
im trying to enable t1/e1 card on cisco 2651xm ios ver [flash:c2600-adventerprisek9-mz.124-25d.bin]
WIC Slot 0:
        T1 (2 port) Multi-Flex Trunk (Drop&Insert) WAN daughter card
        Hardware revision 1.0           Board revision B0
        Serial number     28184225      Part number    800-04614-03
        FRU Part Number     VWIC-2MFT-T1-DI=
        Test history      0x0           RMA number     00-00-00
        Connector type    PCI
        EEPROM format version 1
        EEPROM contents (hex):
          0x20: 01 24 01 00 01 AE 0E A1 50 12 06 03 00 00 00 00
          0x30: 58 00 00 00 02 05 31 00 FF FF FF FF FF FF FF FF
        WIC Slot 1:
        T1 (2 port) Multi-Flex Trunk WAN daughter card
        Serial number     34602219      Part number    800-04477-04
        FRU Part Number     VWIC-2MFT-T1=
        Connector type    PCI
          0x20: 01 22 01 00 02 0F FC EB 50 11 7D 04 00 00 00 00
I have tried command  card type ? Router(config)#card ?
% Unrecognized command
Router(config)#card
appreciate your help [ imsetting up PSTN for voice lab]
Peter Paluch
Do you have a global configuration command controller available? The cards should be available under that command instead of the card command you've tried to use.
Best regards,
Peter
Nagendra Kumar Nainar
The card you have in slot0 is a T1 card and is not T1/E1. So you dont need card configuration. As peter mentioned, you may have to use "controller t1" command to enable related configurations.
HTH,
Nagendra
thank you all, for  inputs, im trying to  configure the controller for "pri-group timeslots 1-3,24", do i need to have PVDM to configure the router for PRI-group, im using advanceenterprise12.4(25), do ineed to changethe IOSandtry again, since under the t1 controllers i dont see the pri-group,  i have added
network-clock-participate slot 1
network-clock-participate wic 0
please advise how can i create pri-group, im setting up the router to simulate PSTN for voice lab
unabel to configure "pri-group" under T1contorllerincisco 2651xm ios spservices, appreciate any help and support.im usign dual port HVWIC 2MFT
