Incorrect Configuration
Sam J
So we are adding a firewall to a remote location to provide IP voice and data access.
The remote location will have Vlan 50 and Vlan 60, data and voice respectively.
The firewall will have an address of 192.168.50.254 which points towards our main connection.
The 3560 will act as a DHCP server for the 60 net.
I have configured the DHCP pool and have excluded address but do not have an outside connection currently.
I have attached the switch's configuration file, any help would be greatly appreciated!
Rob B
Hi Sam,
What problem are you trying to solve here?  You haven't actually listed a question.
it looks like you don't have ip routing enabled. Try the config below (and add a default static route):
ip routing
ip subnet-zero
ip dhcp excluded-address 192.168.50.254
ip dhcp excluded-address 192.168.50.253
ip dhcp excluded-address 192.168.50.1
ip dhcp excluded-address 192.168.60.1
ip dhcp excluded-address 192.168.60.253
ip dhcp excluded-address 192.168.60.254
ip dhcp pool Voice
network 192.168.60.0 255.255.255.0
default-router 192.168.60.253
option 150 ip 10.1.10.220
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0/1
switchport access vlan 50
switchport mode access
switchport voice vlan 60
spanning-tree portfast
interface FastEthernet0/48
interface GigabitEthernet0/1
description Firewall
switchport mode trunk
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface Vlan1
no ip address
shutdown
interface Vlan50
description Data Vlan
ip address 192.168.50.253 255.255.255.0
interface Vlan60
description Voice Vlan
ip address 192.168.60.253 255.255.255.0
ip route 0.0.0.0 0.0.0.0 192.168.50.254
ip classless
ip http server
control-plane
ntp server 10.1.10.1
end
Deepak Kumar
First seen in your switch configuration, looks like, you are missing the Routing enable.
Please enable routing with following commands.
Config t
IP routing
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
