Inner VLAN Routing problem
logianto
Hello,in our company, we purchased 2 cisco 3750x and decided to make the core of the network out of them. I created several VLANs, and I had difficulties in configuring routing between them, namely computers in one VLAN do not ping computers in another, and also it cannot access the Internet (gateway kerio control). Here is my config 3750 and 2960 in which users are connected. I would be eternally grateful for any help.
3750 stack :
Current configuration : 10883 bytes
! Last configuration change at 05:41:21 UTC Mon Jan 2 2006 by admin
version 15.2
no service pad
hostname core01
boot-start-marker
boot-end-marker
no aaa new-model
switch 1 provision ws-c3750x-48
switch 2 provision ws-c3750x-48
system mtu routing 1500
ip routing
no ip domain-lookup
ip name-server 192.168.1.5
ip name-server 192.168.0.22
ip name-server 8.8.8.8
!spanning-tree mode pvst
no spanning-tree vlan 1
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
no ip route-cache
shutdown
interface GigabitEthernet1/0/1
no switchport
ip address 192.168.1.254 255.255.255.0
ip pim sparse-dense-mode
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
interface GigabitEthernet1/0/37
switchport trunk allowed vlan 1,99-105
switchport trunk native vlan 99
switchport mode trunk
interface GigabitEthernet1/0/38
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
interface GigabitEthernet1/0/45
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
i
interface Vlan1
no ip address
interface Vlan99
ip address 192.168.99.254 255.255.255.0
ip helper-address 192.168.1.5
interface Vlan100
ip address 192.168.100.254 255.255.255.0
interface Vlan101
ip address 192.168.101.254 255.255.255.0
interface Vlan102
ip address 192.168.102.254 255.255.255.0
interface Vlan103
ip address 192.168.103.254 255.255.255.0
interface Vlan104
ip address 192.168.104.254 255.255.255.0
interface Vlan105
ip address 192.168.105.254 255.255.255.0
router eigrp 100
ip default-gateway 192.168.1.10
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.1.10
ip sla enable reaction-alerts
2960:
Current configuration : 7769 bytes
! Last configuration change at 06:32:57 UTC Mon Jan 2 2006
version 15.2
no service pad
hostname 2960-99.4
boot-start-marker
boot-end-marker
no aaa new-model
switch 1 provision ws-c2960s-48ts-l
switch 3 provision ws-c2960s-48lps-l
no ip address
shutdown
switchport access vlan 104
switchport mode access
interface GigabitEthernet1/0/49
interface GigabitEthernet1/0/50
interface GigabitEthernet1/0/51
interface GigabitEthernet1/0/52
i
interface Vlan1
no ip address
interface Vlan99
ip address 192.168.99.4 255.255.255.0
ip default-gateway 192.168.99.254
ip http server
Sorry fo late answer, problem was on Windows Firewall, then i turned it off, everything work fine
7 Replies 7
in your original post you said you had two 3750s. How are the 3750s and the 2960 connected ? Provide a schematic drawing showing how the devices are connected, and through which interfaces...
kapydan88
Level 4
Level 4
router eigrp 100 <-
it looks, like you didnt add any network in your eigrp.
router eigrp 100
network 192.168.100.0 0.0.0.255
network 192.168.101.0 0.0.0.255
network 192.168.102.0 0.0.0.255
network 192.168.103.0 0.0.0.255 etc
and try to draw connection and network diagram
I agree that if we knew more about this environment that we would be able to give better advice. Based on the posted configs here are some of the things that I notice:
- on the 3750 all of the access ports are in vlan 1. In the 2960 most of the access ports are in vlan 1 with a couple of access ports in vlan 104. But there is no vlan interface for vlan 1 and so no IP address for vlan 1. So the access ports in vlan 1 will not have IP connectivity.
- the 3750 does have ip routing enabled so it can route. It has several connected subnets so it should be able to route between those subnets. It does have a default route configured. If the next hop of that static default route 192.168.1.10 is working then the 3750 can forward outbound traffic. There is not an active dynamic routing protocol. It is not clear whether the gateway at 192.168.1.10 has routes back to the connected subnets. If it does not have routes for the connected subnets then this is the reason why nothing can get outside access.
- the 3750 configures vlans 99 through 105. But vlan 104 is the only vlan with access ports in it. What are these other vlans?
- the 3750 has quite a few trunk ports. But we have no knowledge what they connect to.
Rick
Thanks for the update letting us know that the problem was the Windows firewall. Glad to know that you got it solved.
Rick
in reality, its a very common problem that is usually forgotten about...
