Input error incrementing on interface
arabella570
How can i get over this issue? please help out.
INTERNET_CR001#sh int f0/1
FastEthernet0/1 is up, line protocol is up
  Hardware is MV96340 Ethernet, address is 0014.6a54.0c45 (bia 0014.6a54.0c45)
  Internet address is 41.23.x.x/30
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 20/255, rxload 29/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:00, output hang never
  Input queue: 0/75/59/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
 5 minute input rate 40060000 bits/sec, 4595 packets/sec
 5 minute output rate 10706000 bits/sec, 4426 packets/sec
     199243576 packets input, 1999729599 bytes
     Received 6398 broadcasts (0 IP multicasts)
     0 runts, 0 giants, 4 throttles
     1139 input errors, 0 CRC, 1 frame, 0 overrun, 1138 ignored
     0 watchdog
     173944696 packets output, 3576836718 bytes, 0 underruns
     2894 unknown protocol drops
     2 lost carrier, 0 no carrier
5 Replies 5
Iulian Vaideanu
Level 4
Level 4
I've read a lot of comments on other forums pointing out that "ignored" errors on 28xx series usually mean that a router upgrade is needed (it can't process packets at their incoming rates and drops / ignores some of them) - what type of device do you have?
actually its a 2811 cisco router.
it is a  2811 cisco router, and what kind of upgrade, is it getting a higher one or just IOS upgrade.
A higher one.
However, the percentage of ignored packets out of the much higher total input packets is negligible (they probably increment when the input rate spikes towards the maximum, you should also see spikes in CPU load) - is this something service affecting?
Yes it affects service.
CPU utilization for five seconds: 59%/47%; one minute: 61%; five minutes: 64%
 PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
   1        1864        1400       1331  0.00%  0.00%  0.00%   0 Chunk Manager
   2       85372       37222       2293  0.39%  0.07%  0.07%   0 Load Meter
   3           4           1       4000  0.00%  0.00%  0.00%   0 LICENSE AGENT
   4           0           1          0  0.00%  0.00%  0.00%   0 EDDRI_MAIN
   5           0           1          0  0.00%  0.00%  0.00%   0 RO Notify Timer       s
   6      685352       42910      15971  0.00%  0.24%  0.23%   0 Check heaps
   7       12072        3229       3738  0.00%  0.00%  0.00%   0 Pool Manager
   8           0           1          0  0.00%  0.00%  0.00%   0 DiscardQ Backgr       o
   9           0           2          0  0.00%  0.00%  0.00%   0 Timers
  10          12          89        134  0.00%  0.00%  0.00%   0 WATCH_AFS
  11           0           1          0  0.00%  0.00%  0.00%   0 License Client        N
  12        4432      181141         24  0.00%  0.00%  0.00%   0 BGP Scheduler
  13         720       37198         19  0.00%  0.00%  0.00%   0 IPC Event Notif       i
  14         128        3103         41  0.00%  0.00%  0.00%   0 IPC Dynamic Cac
Output Cut
