Inputs on Cisco7206 router
saimbt
Hi Gurus,
Requesting help on two parameters on Cisco 7206VXR routers with NPE-G1 and NPE-G2.
  1. Maximum IPv4 routes supported
  2. Maximum NAT entries
-Sai.
paolo bevilacqua
1. no fixed number. However can support all the routes that exist in the internet, even when having multiple BGP peers
2. as .1.
is that enough ?
Giuseppe Larosa
Hello Sai,
as Paolo has noted you should not have memory problems on C7206VRX with NPE-G1 or NPE-G2
be aware that it is still a software based device, so forwarding performance is not very high.
Hope to help
Giuseppe
