48
Beginner
inserting a cisco 3825 NM on a router 2800 series
Hi All,
I have a problem on a cisco 3825 Router. Can I take the Network Modules and insert them on a cisco 2811 or a cisco 2825 ?
will the router work properly after that ?
Thanks !
2 REPLIES 2
Hall of Fame Community Legend
Depends on some NM cards but
Depends on some NM cards but you should be able to do so as long as the 2800 is running the right IOS code and train.
Hi MamaduSaliou, What is your
Hi MamaduSaliou,
What is your NM card exact  model number and your router ios version??
Kafi
Content for Community-Ad
July's Community Spotlight Awards
