Installation a new IOS for a new 7606-S
Hello Dear,
I have a fresh piece of 7606-S router, i am planing to install a new IOS ( 15.2.4S or 12.2.33-SRD8 ) ...
SIP-200 / RSP720 moduls ... would ypu plese provides me a configuration guide for installing IOS for 7600 serise router ...
I have the image on TFTP server .. what shai do ? it will be helpful if you guide step by step ..
your reply is highly appreciated..
Ahmed
Ivan Shirshin
Since you have SIP, you also have to upgrade FPD:
http://www.cisco.com/en/US/docs/interfaces_modules/shared_port_adapters/configuration/7600series/76fpd.html#wp1063108http://www.cisco.com/en/US/docs/interfaces_modules/shared_port_adapters/configuration/7600series/76fpd.html#wp1063119http://www.cisco.com/en/US/docs/interfaces_modules/shared_port_adapters/configuration/7600series/76fpd.html#wp1063130
1. Copy the IOS Image and corresponding FPD package from CCO to the flash card. You can insert it to one of working routers and copy from TFTP server.
2. Put the flash card into disk0 slot on new RSP. Connect on console.
3. Boot the router.
4. If it falls into ROMMON, run:
     confreg 0x2102
     sync
     boot disk0:
5. When the IOS is booted, copy FPD package and IOS file to the sup-bootdisk or bootflash (check the flash size to ensure it is enough to hold both files).
     show sup-bootdisk:
     show bootflash:
     copy disk0: sup-bootdisk:
6. Change the boot string:
     conf t
          config-reg 0x2102
          boot system flash sup-bootdisk:
          end
     wr
7. Reload to boot with new image and make sure everything works fine.
8. Check the modules status and image version:
     show version
     show module
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
Ivan Shirshin
3. Boot the router.
     confreg 0x2102
     sync
     boot disk0:
     show sup-bootdisk:
     show bootflash:
     conf t
          config-reg 0x2102
          end
     wr
     show version
     show module
Kind Regards,
Ivan Shirshin
Kind Regards,
Ivan
Hello my dear Ivan,
as usual your explanation is wonderful, i will install and i will let you know how things are.
Thanking you.
Ahmed
Welcome, Ahmed.
Kind Regards,
Ivan
