Hello Ahmed,
if there is a free fiber pair between CR1 and CR2, as a workaround you can extend the DEMARC of secondary link from CR1 to CR2.
If there is no free additional fiber pair and the only fiber cables are already in use to connect CR1 LAN switch to CR2 LAN switch, some additional configuration is needed.
You can create a new Vlan X to be used just to extend the secondary link to CR2. At this point you would connect the secondary link to an SFP port on the CR1 LAN switch associated to Vlan X.
The link between the switches have to be an 802.1Q trunk carrying all the needed Vlans including the ad hoc extension Vlan X on both sides.
On CR2 LAN switch a port to CR2 router is associated to Vlan X and in this way the extension is performed.
To be noted this second scenario involving the LAN switches should be used only as a temporary workaround as it introduces dependency from good state of CR1 LAN switch to provide backup: if for any reason a power outage happens on CR1, the backup link cannot work.
In the first scenario, no active device in CR1 is involved, so the first scenario might be a mid term solution
In the long term you should make the SP to move the DEMARC to CR2 room.
Hope to help
Giuseppe
