inter vlan routing issue
Sadam
Inter vlan routing not working. two different vlan workstation is unable to communicate.
Hi Saddam,
This is the information regarding the Licenses:
Table 2.       Cisco IOS Software Feature Set Differences
Functions
LAN Base
IP Base
IP Services
Layer 2+
Enterprise access Layer 2
Wide range of Layer 2 access features for enterprise deployments supports Cisco StackPower technology
Complete Access Layer 2
Supports all Cisco Catalyst 2000 and Cisco Catalyst 3000 Layer 2 features, including hot standby protocols
Layer 3
Static IP routing support
Support for SVI
Enterprise access Layer 3
RIP, EIGRP stub, OSPF for routed access, PBR, IPv4 & IPv6 EIGRP stub routing, WCCP, IPV6 uRPF, IPV6 PBR, VRRPv3, Policy Classification Engine, HSRP v6
Complete access Layer 3
OSPF, EIGRP, BGP, IS-IS
VRF-lite
Multicast
IGMP
IPV4 & IPV6 PIM routing
Mobility
Supports Cisco Unified Wireless Networking mobility architecture
Supports Cisco Converged Access mobility architecture with CAPWAP termination at the access
Manageability
Basic manageability
Support for a wide range of MIBs, IPSLA Responder, and RSPAN, PnP, Autoconf, Interface Templates, Secure CDP
Enterprise access Layer 3, Flexible NetFlow for wired and wireless traffic
EEM, GOLD-Lite, and Smart Install Director
Security
Enterprise access security
DHCP Snooping, IPSG, DAI, PACLs, Cisco Identity 4.0, NAC and 802.1x features
Complete access security
Router and VLAN ACLs, private VLANs, complete identity and security; Cisco TrustSec® SXP and IEEE 802.1AE capable in hardware, Device Sensor
QoS
Enterprise access QoS
Ingress policing, Trust Boundary, AutoQoS, and DSCP mapping
Complete access QoS
Support for all Cisco Catalyst 2000 and Cisco Catalyst 3000 QoS features, including per-VLAN policies
Interoperability
Prime 2.1
Identity Services Engine (ISE 1.2/1.3), Mobility Services Engine (MSE 8.0), Improved WebUI
About the configuration, it looks fine now I have a couple of questions:
Are you created the VLANs on the CORE switch? for example:
enable
configure terminal
vlan 10
vlan 20
vlan 30
it can be seen through: show vlan
Now on the EDGE switch you should configure the TRUNKs port with
For example:
interface g4
switchport mode trunk
no shutdown
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
7 Replies 7
Julio E. Moisa
Hi Sadam,
How is your topology, is a L2 switch connected to a Router or the clients are running through a L3 switch, if it is the last option you could enable:
L3 switch
conf t
ip routing
Cisco 3850 12s and edges SF300. Core 3850 directly connected to the ISP SW.
SF300 supports routing and intervlan routing, now for the 3850 you need to verify what license is being used, there is 3 types: Lan Base, IP Base and IP services. The last 2 can be used for routing and intervlan, if your switch has Lan Base so you will be able to run L2 capabilities only. This information can be seen through: show version (at the bottom).
Hope it is useful
I'm the new one for Networking . I don't know about the cisco licensing also clarify to me about the LAN base,IP base,IP service types.
Hi Saddam,
Functions
LAN Base
IP Base
IP Services
Layer 2+
Layer 3
Support for SVI
VRF-lite
Multicast
IGMP
Mobility
Manageability
Basic manageability
Security
QoS
Complete access QoS
Interoperability
Prime 2.1
enable
configure terminal
vlan 10
vlan 20
vlan 30
For example:
interface g4
no shutdown
Thanks frnds now inter vlan working fine also Thanks for your guidence
Hi Saddam,
Happy to hear that, it was a pleasure,
Have a great day!
